Results 1 to 6 of 6
Thread: Pioneer DEH-P6050UB
    HamaTime™'s Avatar
    HamaTime™ is online now VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Default Pioneer DEH-P6050UB
    I'm looking at buying the Pioneer DEH-P6050UB for my 1998 VT, go into my VT S Pack when I buy it...
    currently I've only got the stock unit in there, (it was my Dad's car but he never needed or wanted to get a better head unit, i want one to play all discs and be iPod compatible) but I've heard that not all units are compatible with Commodores and that Commodores are notorious for the difficulty with changing audio systems (thats what I've heard, never tried doing an audio system myself)
    is the Pioneer DEH-P6050UB compatible, is it a good unit?
    2008 Pioneer DEH-P6050UB 6050UB USB CD MP3 WMA Player - eBay Players, Audio, Video, Car Parts, Accessories, Cars, Bikes, Boats. (end time 06-Jun-08 22:00:00 AEST)
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    the vt is one of the easyer cars to do
    never head of any commodores that have problems changing stezzas over
    god luck
    VYII SV8
    Aug 2006
    Toowoomba
    For about $10 you can buy a wiring loom adapter than makes the connection job very easy - you can pretty much join the head unit's wires to the adapters wires of the same colour, it's a simple plug and play process. You don't have to cut your car's wiring loom at all, and the wiring will already be done when you want to switch the Pioneer into your S pack. Best of all, the old head unit will plug straight back in and the car is back in factory condition.
    From memory, VTs have a double DIN stereo and the Pioneer is a single DIN size, so you will also need a fascia kit to plug the hole in your dash and mount your new unit. Pick one up from Autobarn while you're buying the wiring adapter - they're about $30-40.
    The head unit looks good - just pick one with the features and appearance that you like, compatibility with particular cars is usually not a problem.
    VR V8 Manual Executive
    May 2008
    I am starting to sound like a broken record but if your car has an electric aerial and you want it to work properly don't buy a pioneer. Just done it and they don't have a dedicated aerial switch wire, just a amp switch wire which can be used and it won't give factory functionality of your electric aerial. It will go up and down but if the head unit is on it is up regardless of whether you are listening to a CD or the radio. Unlike the factory unit which only puts it up when you turn on the radio.
    H
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Who cares... It's only an antenna and a stupid reason to rule out a perfectly good range of head units.
    vrollin is offline Banned
    VE SSV Ute
    Sep 2007
    How did the install go mate? Im looking at that very headunit to go in my VX, I have no concerns with wiring it up, my only worry is the depth of the unit. Did it fit all the way in?
    Ive seen a write up where some bloke had to cut the back end out of the metal shroud of the double din area to make a unit fit with rcas and antenna, this unit has a whole extending bit poking out the end of it...
  1. Pioneer H/U
    By Jecs in forum Car Audio
    Last Post: 23-09-2007, 11:25 PM
  2. pioneer sub
    By MUNTED6 in forum Swap / Wanted to Buy / Trade
    Last Post: 20-09-2007, 06:17 PM
  3. WTB: Old Pioneer AV
    By breast69au in forum Swap / Wanted to Buy / Trade
    Last Post: 24-06-2006, 04:01 PM
  4. CDT vs pioneer
    By VLACS in forum Car Audio
    Last Post: 18-04-2006, 05:40 PM
  5. Pioneer 12
    By Super_star in forum Parts And Other Items For Sale
    Last Post: 26-03-2006, 09:53 PM
