Results 1 to 7 of 7
Thread: first sound system.. help!
    VS manual wagon
    Apr 2008
    sydney
    Question first sound system.. help!
    hi,
    ive just bought a 4 chanel amp to run my sub and two front speakers off.
    i plan to run my rear speakers off the head unit.
    i have the head unit installed only it only has one of the rca ports (ie 2 holes)
    anyone know how i should set this up?? i am thinking i will bridge the sub over 2 ports.
    i know this might be basic but i havent been able to find the answer and its stopped me from progressing.
    cheers
    mat
    '97 VS Commodore + '98 E36
    Apr 2005
    should've purchased a better head unit with multiple RCA out puts
    but heres what you can do, you can purchase this unit called a HI to LO level converter from jaycar for around the $15 mark
    Jaycar Electronics
    what this does is converts the normal spearker wire outputs from the head unit to RCA out puts
    you will need to tap into the either the front or rear speaker lines from the headunit, this will then give you 2 extra RCA outputs for your 4 channel amp
    OR if your 4 channel amp is fitted with an 'output' you can route the output of the amp back into the 3/4 channel RCA 'input' of the same amp
    but i would recommend you do the first suggestion
    VYII SV8
    Aug 2006
    Toowoomba
    Or you could just buy 1 RCA to 2 RCA Y-splitters, which would be a lot easier.....
    davey g-force's Avatar
    davey g-force is offline I'm a sceptic...
    Phantom MY09 VE SSV A6 & Holden Cruze CDX M5
    Sep 2005
    "...the winner is..."
    Quote Originally Posted by klaw81 View Post
    Agreed. Yep just buy a pair of RCA splitters and voila! Your two RCA outputs will become four. Too easy.
    Quote Originally Posted by CSP (aka Rufys) View Post
    Look, all the update is going to be is like going from VX to VY or VY to VZ. Same car with different front/rear ends and updated interior. But it will be the VF, not the VE II.
    VS manual wagon
    Apr 2008
    sydney
    thanks for your help,
    ive decided to just buy a new head unit as the one i have isnt that great anyway
    the guy in strathfield recomended the sony 570
    http://www.sony.com.au/xplod/catalog...sp?id=CDXGT570
    what do you think?
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Personally, i think sony xplode gear is CRAP. You would be better off spending a bit extra and buying something along the lines of Alpine or even Pioneer.
    But if you just want something that does the job, just buy the xplode unit.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    roon_VR's Avatar
    roon_VR is offline VR executive Commodore
    3.8 V6 executive SII VR
    Mar 2007
    The new sony xplod head-units are surprisingly not bad. However, if you can afford the extra dosh, better to get an Alpine or Pioneer with 3 sets of RCA pre-outs. If you're on a budget, get a sony xplod or even buy a second hand Alpine unit.
    My car audio:
    CD tuner: Alpine CDA-9884E with Ipod interface
    Front speakers: Alpine Type R SPR-17S 6.5 component speakers, powered by a avant-garde 23dxi 2 channel amplifier - 2x51 watt RMS
    Rear speakers: pioneer coaxials connected to tuner
    Subwoofer: Alpine Type R SWR-1222D 12" 2 ohm dual voice coil 500 watts RMS powered by a response precision 2x150 watts RMS 2 channel amp bridged to 500 watts RMS @ 4 ohms
  1. Sound System high pitch sound
    By liquidforce_134 in forum Car Audio
    Last Post: 16-07-2008, 10:31 PM
  2. Help with a new sound system
    By Resident-Seven in forum Car Audio
    Last Post: 16-07-2008, 06:04 PM
  3. VY sound system
    By Loupy31 in forum General
    Last Post: 10-05-2007, 09:49 AM
  4. just bought sound system, will it sound good
    By pier_one in forum Car Audio
    Last Post: 02-10-2005, 01:27 PM
  5. More On My Sound System
    By Jase VK in forum Car Audio
    Last Post: 13-09-2003, 10:59 PM
