Results 1 to 11 of 11
Thread: Head unit stuck in demo mode
    VP
    Jan 2008
    Default Head unit stuck in demo mode
    hello
    having some trouble with the head unit i just installed
    it's a kenwood kdc-mp239
    it comes in a default demo mode.. where the units features are continually scrolled across the screen..
    anyway.. the manual says how to take it off demo mode.. but it doesnt respond when the steps are taken.. same thing happens when i try to set the clock..
    any ideas of how to fix this? or has this happened to anyone else?
    VS
    Sep 2008
    Did you manage to fix this ? I have the same problem
    Daz
    Quote Originally Posted by onni View Post
    hello
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    hmm...a lot of units have to be switched off but ignition on for these functions to work. Without knowing kenwood like the back of my hand I'm not sure but have tried the process with the deck switched off?
    Aug 2008
    Quote Originally Posted by . View Post
    or with it switched on? lol
    they'll normally only display the demo with them turned off.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Quote Originally Posted by TheyDontWantMusic View Post
    No, switched off. Many units have their initial setting menu only accessible from the unit being off. Pioneers require the unit to be off and either the FUNCTION or SOURCE button to be held while the unit is off to get into the initial settings.
    Tasmaniak's Avatar
    car
    Apr 2005
    Sony is the same...as is newer Clarion units. Not a Kenwood dealer though so have not had much experience with them...I can't even figure out how to set the time on them. I still have one in my sound board and when it gets shut off I wait until midday to turn it back on! LOL
    VT S2 3.8 & VT SS S2
    Jan 2009
    I just got this 2 days ago and yeah I had this problem and I HAVE THE SOLUTION after a bit of mucking around.
    You need to enter MENU mode. To do this you press the little search button next to the volume knob. What you do is hold that button for about 1-2 seconds. It will then come up with menu demo on. I think you press the volume knob and it will go off
    It is stupid to have them come with demo on but I guess they want to advertise their products and tell you its features.
    Otherwise I have found this headunit very good so far running my speakers off a Response Amp.
    Still fiddling around with the best equaliser settings.
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    Yea, that's the way to do it on the Sony's too (check your manual for exact instructions on how to get to the menu).
    VTS2
    Feb 2009
    Question
    Quote Originally Posted by alien View Post
    I tried this with my Sony XR-C2600 unit which is also stuck in demo mode, BUT didn't work. It was already installed in my VTii when i bought it second hand, it came with a manual(2000 model) but mentions nothing about this stooopid function which kicked in when i started having starting/battery problems with car itself.
    My unit has a separate 'menu' button, which normally you can access when the unit is on. Tried holding 'it' down as mentioned for 1-2 secs, even up to 10 secs and still no-go.
    Have tried holding down the 'source', 'menu', 'funtion', 'skip/right' & 'off' buttons but again still 'no worky'
    I KNOW there is a fix for this (multiple buttons perhaps?) because after resigning myself to not having a stereo that worked i gave up and drove around without it working for 3 mnths. I booked the car in for a service at my local Holden dealer and when I got it back WOW! it was working again, spoke to the service manager about who worked on it and how'd they get it out of demo mode and he said that after talking to technician he had no answer.
    So it either fixed itself (yeah right) or most likely someone else did some of the service as well and knew how to fix it.
    Can anyone pluuzzz help, I'm going crazy searching the net looking for a fix
    VTSS GEN3, VKSSA REP V8, VP BT1 V8
    Feb 2006
    darlington
    kenwoods actualy have a reset button on the face pannel (mines under the volume controll) hold that in for a few seconds with a pen or sumthin and that should fix it as i had this problem with mine
    BAD COP!! NO DONUT!!
    VTS2
    Feb 2009
    Taa, yeah I have tried that too, as per the instructions in the manual when replacing/disconnecting car battery.
    The Sony's reset is under the faceplate, all it did was reset the clock to '1:00' still can't get it out of demo-mode
  1. stuck in limp home mode
    By stocky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-12-2006, 10:17 PM
  2. CD stuck in Clarion DXZ535 head unit
    By SHIFTA in forum Car Audio
    Last Post: 26-03-2006, 11:03 AM
  3. head unit help
    By scolari in forum Car Audio
    Last Post: 08-01-2006, 04:07 PM
  4. Vacuum problem? with feet/face/demist mode unit
    By gaza1970 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-10-2005, 10:25 AM
  5. Fuel Consumption Normal Mode / Power mode (Overdrive)
    By peeete in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-09-2004, 10:05 AM
