Results 1 to 16 of 16
Thread: CAT interface installation
    VX
    Jun 2008
    Default CAT interface installation
    hey guys - finding it hard to locate info on installing one of these CAT things, has anyone done it? There is one on ebay but how hard are they to install? where do you put the infra red transmitter? do they work as well as they say? any info would be great because I would like to try myself. tnx.
    redcv6's Avatar
    redcv6 is offline supercharged intercooled
    vy ss ute, diesel landcruiser 100s, hq panel van
    Aug 2006
    Ringwood
    VX
    Jun 2008
    VY S Sedan
    Sep 2007
    VX
    Jun 2008
    VYII SV8
    Aug 2006
    Toowoomba
    I've installed one in my car - piece of cake. Connect power, earth and signal wires, hide the little box in the console somewhere, and point the IR led at the head unit. I find it works very well - no problems at all so far. The maker of the CAT products is actually a member of this forum (RonnieM) and he's a very helpful guy.
    VX
    Jun 2008
    Thanks for the info klaw81!!! I've heard nothing but good things about the product, I think that just made up my mind. tnx.
    Factory Blown VY S2 Calais
    Jun 2005
    Brisbane Bayside
    Last one I saw on ebay went for $160. $220 at Northfield etc. They work fine, the CAT10 is better IF you have a unit that accepts the 3.5mm remote jack.
    Installation is as easy as Klaw says - I actually poked the led up between the unit and fascia (little blue dot on this pic I played around a bit to get the spot with best reception.
    On my current unit, I have an alpine with the 3.5mm remote jack and purchased a SWI-JACK off ebay $70 inc postage. Much cheaper than the CAT and arguably just as good. It seems a shame to have to buy a product from o/s but at 1/3 the price even factoring in postage it's just crazy.
    I have an old one of the pac swix units lying around if you want it - equiv of the CAT09 except I can't comment on VT compatability.
    PESWIX SWIX SWI X UNIVERSAL STEERING WHEEL RADIO CONTOL - eBay Other Installation Products, Installation Products, Car Electronics, Consumer Electronics. (end time 07-Jul-08 22:06:30 AEST)
    VYII SV8
    Aug 2006
    Toowoomba
    I looked at the PAC products too, but my model of head unit wasn't officially supported. I picked up a 2nd hand CAT09 from this forum and after a little teething problem (electronic glitch fixed by manufacturer - cheers RonnieM!) it was all sorted.
    My IR led is hidden in the centre console just behind the gearstick which seems to work pretty well - even if there isn't a direct line of sight to the IR receiver, the signal seems to bounce around the interior and gets there in the end...it must be a powerful signal.
    VZ Acclaim
    Aug 2008
    To install the CAT10 into a commodore VZ, the installation instructions state:
    "Ground the vehicles Black/Yellow trace and connect CAT10 Brown to vehicle Brown."
    Does anyone know which slots these are on the connector at the back of the stereo cavity?
    + + +_ + +_ + +
    _+ +_ + +_ _+ +
    + + +_ + +_ + +
    (+'s represent a connection on the socket. _'s are to help layout the +'s properly on the screen)
    Is the Black/Yellow trace simply the GND of the remote signal (shown as # below):
    + + +_ + +_ + +
    _+ +_ # +_ _+ +
    + + +_ + +_ + +
    I assume the vehicle brown the STEERING REM output (shown as # below):
    + + +_ + +_ + +
    _+ +_ + +_ _+ +
    + + +_ # +_ + +
    Can anyone confirm this?
    VYII SV8
    Aug 2006
    Toowoomba
    That looks about right.....but it's best to check by cutting a little of the cable wrapping away to check for sure. The factory cable is long enough to be pushed out into passenger footwell, if you're having trouble making the connections elbow-deep inside the dash.
    VZ Acclaim
    Aug 2008
    Thanks klaw - I went to JB HIFI today they said it would take about 1-2 weeks to get a CAT10 in - and I had to pay $266 upfront
    How easy is it to get access to behind the stereo from the passenger footwell? - Is there any info on the process for a VZ?
    Jun 2005
    Brisbane Bayside
    Have you considered the PAC Swix ? $70 on ebay inc postage and you'll have it in 5days.
    VZ Acclaim
    Aug 2008
    Quote Originally Posted by Fletch_QLD View Post
    Too late - I've already blown my money
  15. #15
    VYII SV8
    Aug 2006
    Toowoomba
    Quote Originally Posted by scoMale View Post
    Getting access to the back of the headunit from the footwell would be quite difficult. However, you can release the headunit wiring loom's plugs from the little clips. Once released, there's enough cable length in the harness to poke the plugs out into the passenger footwell. That way, you can make your connections out in the open rather than trying to fit both arms into the depths of the dash.
  16. #16
    VZ Acclaim
    Aug 2008
    Quote Originally Posted by klaw81 View Post
    What is best to poke the cables through? - Pop the glovebox off the clips, then poke it through the hole left behind?
  1. cheap OBD2 interface
    By hakhawk in forum Electrical Wiring / Questions
    Last Post: 09-11-2007, 07:19 PM
  2. HELP with RS232 interface!
    By shaggerz in forum The Pub
    Last Post: 04-01-2006, 10:39 PM
  3. OMBII interface VX
    By genIIIbandit in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-11-2005, 03:48 PM
  4. OMBII interface
    By genIIIbandit in forum Electrical Wiring / Questions
    Last Post: 12-10-2005, 09:40 PM
  5. OMBII interface
    Last Post: 11-10-2005, 10:59 PM
