Results 1 to 5 of 5
Thread: Amp prob: turning itself off
    VT V6 sII-Phantom Mica
    Sep 2005
    Scone, NSW
    Default Amp prob: turning itself off
    I have a problem with my amps, when i turn them on (switch on remote wire) the light on the amp will come on and then slowly fade out, sometimes it wont even come on. It is all connected correct and no fuses are blown, im not sure weather itcould be that its not getting enought power, but its been running fine for the last 1.5 - 2 years. anyone have any ideas what it could be.
    VH and VT S2 Berlina ecotec
    Aug 2007
    Brisbane-northern suburbs
    Sep 2005
    Scone, NSW
    It should be fine, its barely a year old. car was serviced 3 weeks ago and all that was checked.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Try brifging from the B+ to the remote terminal to see if it stays on then, if it does you might have to investigate the head unit and wiring, if it goes off still then maybe your amp is having troubles.
    Reaper
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Good suggestion from VrWagz - also it can be worthwhile to check the power and ground connections at the amp, the ground point to the chassis, and the main fuseholder.
    It's been working fine for some time yes, but in that time connections have had the chance to get a little oxidised or corroded, or work loose. I've seen one blokes amp not power up because of a flaky connection in the fuseholder, so....
    (in other words it looks to me like the voltage supplied to the amp is dropping away once it starts to draw some current - usually indicateds a high resistance connection.)
    Of course, the other option is there might be a fault with the amp!
    Anyhow, best of luck. Cheerz!
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
  1. amp not turning off
    By Burnout_bro in forum Car Audio
    Last Post: 01-09-2008, 10:05 PM
  2. vh not turning over??????
    By NOT.BT1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-04-2007, 07:11 PM
  3. Clunking when turning...
    By VNCalais98K in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-01-2007, 11:57 PM
  4. turning clunking
    By alex88 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-01-2006, 11:12 AM
