Results 1 to 7 of 7
Thread: remote wire problem
    Nov 2005
    Default remote wire problem
    Im installing a 10" JL Audio Sub running off a 4 channel kicker amp. The headeck is a Blaupunkt London mp37. Everythings installed and works fine, its just that the amp doesn't turn off when the car does, therefore draining the battery. The remote wire's connected properly, so I don't know what the problem is.
    Any help?
    Thanks
    VK
    Jul 2004
    Nov 2005
    What am I supposed to check, ie what could be the problem with the wiring to the battery? as i said the headeck works fine, just that the amp doesn't turn off when the car does.
    sorry for the dumb questions just never had this problem before.
    thanks again
    '97 VS Commodore + '98 E36
    Apr 2005
    ..possibilty that the remote wire from the head unit may be buggered
    had a similar problem with a previous head unit, except the head unit would not turn on the amps
    try tapping the ampflier's remote wire to the switch/ignition (should be yellow i think) wire of your head unit and see how you go
    thats the solution i used for the previous head unit.
    Nov 2005
    Well the block with the RCA/remote wire outs from the headeck is brand new so i don't think theres anything wrong with the headeck's remote wire. anyway ill try tapping it to the ignition wire and see what happens.
    thanks
    VK
    Jul 2004
    was thinking that you might have the constant connected to the +12v, causing the head unit to stay on and hence the amp?
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    If you disconnect the trigger wire from the amplifier, does the amp still stay on? If so, your amp is cooked!
LinkBacks (?)
  1. 13-07-2008, 01:40 PM
  1. VY remote on wire for amp
    By c0mmodore in forum Car Audio
    Last Post: 05-02-2008, 08:10 PM
  2. can i run a remote wire of another remote wire
    By Burnout_bro in forum Car Audio
    Last Post: 07-05-2007, 11:16 AM
  3. Remote wire
    By [NatHAn] in forum Car Audio
    Last Post: 15-04-2007, 02:46 PM
  4. remote wire on pionner DEH-P1Y
    By beefcream in forum Car Audio
    Last Post: 28-04-2006, 01:41 PM
  5. Amp remote wire
    By yogi_6_9 in forum Car Audio
    Last Post: 19-01-2006, 01:41 AM
