Results 1 to 4 of 4
Thread: Wiring Kicker CVR DVC 2ohm at 2ohm load?
    VX Acclaim S2
    Apr 2006
    Default Wiring Kicker CVR DVC 2ohm at 2ohm load?
    Is it possible to wire a Kicker 12" CVR DVC 2ohm sub to a ZX 400.1 Kicker amp at 2ohms. Or can I only have the sub running at 4ohms???
    I'm guessing I have to change my sub to a DVC 4ohm to have it running at 2ohms??? Is this correct?
    | evaN |'s Avatar
    | evaN | is offline mmm bass
    VT
    May 2006
    SE Melbourne
    The amp isn't 1 ohm stable so you'll have to run the voice coils in series to make it 4ohms. You'll get 200wrms to your sub so its not pushing it to its full potential but it should sound alright until you get a better amp.
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    Ruso, one of them really needs to go.... You can...
    a, Get a 4ohm DVC sub
    b, Get a cheaper smaller amp that is 1ohm stable
    Basically all you need is an amp that will run 400 into 1ohm or 400 into 4ohms. Personally, I would be swapping out the sub IF you can.
    There is also the option of running it at 4ohms like mentioned above and then using a second 400.1 (same model and all the jazz) and using each amp to power an individual coil
    VX Acclaim S2
    Apr 2006
    thanks all. I've gone and swapped it for a 4ohm DVC sub. Just waiting for it to arrive.
  1. Kicker Audio
    By Terence in forum Car Audio
    Last Post: 17-08-2009, 07:48 PM
  2. F/S Kicker Sub
    By bush_basha in forum Parts And Other Items For Sale
    Last Post: 07-02-2007, 06:44 PM
  3. kicker subs
    By commyvx in forum Car Audio
    Last Post: 18-07-2006, 09:58 PM
  4. 4Ohm Sub & 2Ohm Amp
    By Jazack in forum Car Audio
    Last Post: 04-05-2006, 06:34 PM
  5. Kicker Solo Baric 18" & Kicker Equalizer
    By sbkvp in forum Car Audio
    Last Post: 05-12-2004, 07:05 PM
