Results 1 to 7 of 7
Thread: what dose a distribution power block do?
    dethballer is offline Stuck with a v6
    2002 silver belina v6
    Dec 2006
    Default what dose a distribution power block do?
    I am in the middle of setting up my second amp, and found out that I need a distribution power block. But after seeing a few pictures of them, it got me thinking...
    If I got a small ring of thick cable and connected my power cable to that, and another 2 cables of the same size to the ring and have those 2 cables going into the amps I wouldn't need to get one, because all they are is a chunk of metal coated in plastic.
    Yeah, I know that a distribution block only costs $10.00 but I have the cable sitting around and I don't want to go back into the shops as I will leave with alot more then just the block
    | evaN |'s Avatar
    | evaN | is offline mmm bass
    VT
    May 2006
    SE Melbourne
    I guess you could do that if the wire is big enough.
    the main reason you get a distribution block is because you usually have a larger wire from the battery to the back, and then two smaller wires to the amp. This way you can use the right fuse at the right places. A larger one at the front and then 2 smaller ones in the boot
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    just lug the ends with 8 or 10mm lugs and bolt them together with 8 or 10mm bolt. Rap up in some scotch 23 if you have some or just some electrical tape if you dont.
    Reaper
    VY SS
    Aug 2004
    SE Victoria
    VrWagz1's Avatar
    May 2008
    wollongong
    Obviously you have the correct rated protection in place
    Reaper
    VY SS
    Aug 2004
    SE Victoria
    well if you are going to fuse the feed wire at the smaller wires rating why have the larger feed wire.........
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    im guessing that he has a large feed wire from his batt to his boot and relised that he needs more connections from the feed wire so needs to "split" the wire...
    Yes, you can do what you described... but its a little add-hoc and gay. Just buy the distroblock....
    *yes, you can do what you asked... please fuse everything... im being a toss cos i like things done overkill lol*
    aZk.
  1. dose any 1 no how to pull apart the power steering pump
    By dougs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-04-2006, 04:26 PM
  2. Distribution block, connections and fusing
    By Brycestro in forum Car Audio
    Last Post: 31-03-2006, 07:36 AM
  3. Removing Centre Console Power Switch Block
    By VTSSDUDE in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-12-2005, 10:19 PM
  4. Air distribution drama
    By djburls in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2005, 12:31 AM
  5. Distribution blocks - where?
    By MasterOfReality in forum Car Audio
    Last Post: 10-01-2005, 10:03 AM
