Results 1 to 10 of 10
Thread: Installing speakers into VN Commodore
    '06 VZ Commodore Exec
    Jul 2008
    Ballarat
    Post Installing speakers into VN Commodore
    Hey guys, I own a '90 VN Commodore S and looking to install recently purchased speakers into it.
    I have a pair of 6x9 and a pair of 6.5" speakers which I want to install, currently the car still has the stock speakers in the front and rear.
    I took my car to Autobarn to get the job done properly, but the blokes there claim that I need to purchase a flat parcel shelf to mount the 6x9s properly.
    Is this the only way I can get the speakers into my car, or are there other ways to get the job done? And whats the best way to mount the 6.5" speakers into the front?
    Any opinions would be greatly appreiciated.
    VK
    Jul 2004
    Ii made up some risers for the 6x9s in the back and used the standard parcel shelf in my old vn. In the front I fitted vr speaker pods to the doors, should be able to get them really cheap from the wreckers nowadays. Really easy to fit too.
    Jul 2008
    Ballarat
    I was gonna buy some risers, but the bloke at Autobarn says that they make the speaker sounds like crap, not producing any bass or something along those lines.
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    I have the VR speaker pods in the front doors also.
    When I had 6x9's I used small spacers I made out of some MDF (about 1cm high).
    VK
    Jul 2004
    if they arent sealed properly the risers will make the speakers sound like crap. Probably right with a dodgy autobarn install
    Jul 2008
    Ballarat
    Righteo, I've found some VR speaker pods from a mate, so the front speakers are covered.
    But whats the best way to seal risers for the 6x9s? I want to avoid having to buy another parcel shelf just to install some cheap speakers.
    Sorry if these are stupid questions but I have never installed a stereo before.
    VK
    Jul 2004
    just make sure you have no airgaps between speaker-riser-parcel shelf. You will most probably need to cut the parcel shelf a bit to fit the basket in even though you have the risers.
    Jul 2008
    Ballarat
    vn executive
    Aug 2008
    calwell canberra
    cant you just cut a hole in the back tray ??im haveing the same problem but im just gonna cut the hole and put the 6x9s in
    Jul 2008
    Ballarat
    I'm not entirely sure Mr Big Westy, but to get the 6x9 in you may have to cut into the metal frame beneath the parcel shelf, which is illegal and makes the car unroadworthy.
    If your parcel shelf is completely flat then you should be fine, but mine is stock and has curves which makes it hard to just "drop it in there".
  1. installing speakers in vn
    By haynze in forum Car Audio
    Last Post: 20-07-2009, 08:21 PM
  2. Installing Speakers in rear
    By Pretender in forum Car Audio
    Last Post: 08-04-2006, 02:51 AM
  3. Installing rear speakers help
    By ozzie_online88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-02-2006, 08:35 AM
  4. installing VY 6x9 Speakers
    By cb1177 in forum Car Audio
    Last Post: 08-01-2006, 11:18 PM
  5. Installing front speakers into a VC.
    By SSGEN-3 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-04-2005, 10:15 AM
