Could some one please help i am trying to remove my standard cd player in my vt i need some help. how do you remove it is it easy.
See those 4 holes on the left and right edges of the unit? Get a wire coat hanger, clip 2 C shaped "bits" of wire, and jam them into those holes.
Then you can pull the unit out, and throw your new one in!
But you should also disconnect the - terminal of your battery if you plan to take anything or add anything to you system
hi there, for my VZ ute, does anyone know if and how easy it is to swap a holden single disc CD player with another Holden brand 6 disc CD player..
cheers
