Results 1 to 4 of 4
Thread: need help please
    benny mckellar's Avatar
    benny mckellar is offline boobs,blowers,burnouts
    vr ute
    Mar 2008
    Default need help please
    hi i'll admit it i know stuff all about amps and what not so can i run 280 watt speakers off a 600watt monoblock amp or will it just blow the speakers
    TWOJZ is offline Banned
    VL shagon ;)
    Apr 2008
    Adelaide!
    you could do that,
    but I assume the speakers, aren't subs, and a monoblock only has one channel, so you will no longer have stereo sound, plus, most monoblock amplifiers won't play full range, they will only play bass.
    if its subs you're talking about, then sure, you can do it, without blowing anything up.
    you could run a 1 watt speaker, off a 10,000watt amp without blowing it.
    I don't know if the power figures you've given are rms, or imaginary peak, never going to happen numbers, but it doesn't matter.
    | evaN |'s Avatar
    | evaN | is offline mmm bass
    VT
    May 2006
    SE Melbourne
    If the speaker is a sub than the amp will run it fine. Remember its better to over power then to under power.
    If its a normal speaker eg. 6x9 then it wont work. Pretty sure most if not all monoblocks are class D amps and therefore are designed for low frequencies. When compared to class AB amps, class D have more distortion but when running at low frequencies, it isn't noticeable. Thats why class AB are best for normal speakers but can be used for subs and class D are for subs.
    VY SS
    Aug 2004
    SE Victoria
    evan - monoblock and class d are not always hand in hand. usually yes but there are stilll plenty of AB monoblocks and what not.
