Results 1 to 6 of 6
Thread: Wiring a Head unit
    vs 96 acclaim
    Nov 2007
    Default Wiring a Head unit
    I've wired up quite a couple of vs head units but thats thanks to the colour coding chart on this site...A mates just asked me to hook up one in his camry and just wondering how i would go about distinguishing what wires which? -e.g constant, acc, speaker +- etc. i was told by an mechanic mate of mine i could use one of those fuse tester things..
    '97 VS Commodore + '98 E36
    Apr 2005
    you will def need a multi-meter tester...$10-$20 from any automotive store.
    what i usually do is
    first distinguish the power wires...Constant, Switch and Ground
    -Ground should be obvious, Black
    -Constant: with the keys out of ignition, use the multi-meter, black probe to the ground of the car and test each wire with the red probe, when you see 12+ volts, BINGO!
    -Switch: with the ignition on ACC, do the same with the black probe and test each wire again with the red probe, when you see 12+ volts you've found the winner.
    Apr 2005
    as for the speakers i use a AA 1.5v battery.
    What you wanna do is try pair up the obivous colors
    eg: dark green with light green, dark blue with light blue.
    once all paired up you should have 4 set of wires for speakers
    with the AA battery put one wire from a pair on the positive and negative terminals of the battery, you will hear a popping noise, find out which speaker the popping is coming from and there you go!
    do the same with the remaining speaker wire.
    remember to tag the each set of wires once you have distinguished them so you dont mix em up.
    vs 96 acclaim
    Nov 2007
    thanks for the quick reply guys
    as for the AA battery thing you were talking about ridah..how would you tell which one would be positive and which wire would be negative, or will it only crackle when you've got the appropriate wires on right terminals on the battery? which would mean the wire on the positive terminal of the battery would be the positive wire when it crackles..hope that made some sense
    Apr 2005
    yeah i know what ya mean mate... it will crackle regardless of which way you hook it up to the battery, most of the time the lighter color wires should be positive, what i usually do is, temporarily twist the wires that are correct together (maiking sure they wont short circuit of course)then turn the head unit on.
    put the fader to the front...turn the bass up and listen.
    if it sounds funny and theres no bass at all, that means the speakers are out of phase. turn off the car and switcha-roo the front speaker wires.
    do the same with the rear.....then front speakers should be in phase as a pari and so should the rears
    then balance out the fader and listen if the bass sounds right, if not just switch the polarities of rear OR front speakers
    lol i hope you get what i mean.
    if not, hopefully some one can explain in detail.
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    Don't know what year we are talking here but this is for a 95....pretty generic yotas are but if doesn't look like what you have at all then let me know the year...
    +12V DC Battery(Constant) Blue/yellow Dome 20 amp Junction block 2
    Switched Accessory Gray Cig/radio 15 amp Junction block 1
    Ground Brown
    Power Antenna Black/red Also pink/blue
    Left Front + Pink
    Left Front - Purple
    Right Front + Light green
    Right Front - Blue
    Left Rear + Black
    Left Rear - Yellow
    Right Rear + Red
    Right Rear - White
    lol, just looking at that and I realised that the speaker wires are the same for the for a new 2007 toyota tundra....somethings never change eh?
  1. Vs Head Unit Wiring And Eurovox
    By gazza777 in forum Car Audio
    Last Post: 29-12-2008, 06:43 PM
  2. Replies: 3
    Last Post: 19-04-2008, 07:11 PM
  3. Wiring a new head unit?
    By cducktv in forum Car Audio
    Last Post: 13-10-2007, 10:08 PM
  4. Wiring DVD head unit and laws
    By revin rosco in forum Car Audio
    Last Post: 28-07-2006, 11:37 PM
  5. Wiring for pioneer head unit
    By Street Lethal in forum Electrical Wiring / Questions
    Last Post: 11-06-2006, 12:43 AM
