Heya guys,
I have a Response 2x150 bridged running a kenwood 1500w sub, worked fine for a week, but i've killed the sub, it wasnt running overly hard, now it just sounds like someones thrown a few bearings into it, makes a soft rattle.
I have 2 options, I can go to JB or autobahn, buy another, and take mine for a refund for DOA... which i would prefer to do, otherwise its a better sub..
the Kenwood sub was rated @ 380W RMS, and i doubt i was running it near that, I dont understand why its died.. i also had to replace the bonnet fuse.. I'm thinking it had something to do with the dodge on my amp, remote cable broke, so i rigged up a switch from constant 12v to the remote and it worked fine for the week, then just stopped..
any help is appreciated!
Joel.
alpine type R 2+2 ohms FTW! 500 watts RMS
My car audio:
CD tuner: Alpine CDA-9884E with Ipod interface
Front speakers: Alpine Type R SPR-17S 6.5 component speakers, powered by a avant-garde 23dxi 2 channel amplifier - 2x51 watt RMS
Rear speakers: pioneer coaxials connected to tuner
Subwoofer: Alpine Type R SWR-1222D 12" 2 ohm dual voice coil 500 watts RMS powered by a response precision 2x150 watts RMS 2 channel amp bridged to 500 watts RMS @ 4 ohms
mate ilove car audio and i would have to say thers been alot of power surge in the amp probably couldnt handle the sub which has caused to stuff a coil in the sub itself but there could be alot of dust in sub so try turning it on its face and turn it up and see wat happens.
I believe i have killed a coil in the sub, so i might head down to JB and get a bit dodgy, might have a new sub for sale next week haha
XeKToReX
You would have burnt the sub's voice coil... That amp can make 500Wrms when bridged so it can easily toast a 380Wrms rated sub if run hard. If I was you, i'd look for a sub with a higher RMS power rating and be careful when listening![]()
^^^^ What he said. That Jaycar amp can smoke a small sub in the blink of an eye.
Be careful though... it's 500wrms at 4ohms. So a SVC at 500wrms or a DVC 2ohm sub at 500 (250 each coil) would be good. Nothing below 450rms and nothing above 550rms is what you are going to be looking for....or a pair of subwoofers?
