Results 1 to 7 of 7
Thread: Upgrading factory system
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Default Upgrading factory system
    OK it's time for some decent sounds for my ride.
    i want to upgrade the factory speakers and fit a decent sub in the boot. was considering replacing the factory rear speakers with some new 6" jobies and and 10 inch sub in the boot running of a amp. can i use a single amp to power both the sub and the 6" speakers in the tray or do i need to use seperate amps? was considering using a jaycar presision responce amp these seem to be a good little unit
    any suggestions/advice?
    Body by Holden, Soul by Brock
    the Legend will live forever
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    It depends on the speakers involved, but it is possible to run them all off a 4 channel amp, but not very easily. I'd reccomend running the 6" off the head deck and just amping the sub.
    Apr 2006
    Auckland NZ
    don't you get a better sound quality if you run the rear 6" speakers from a amp also?
    1991_Vn2nV's Avatar
    Mar 2006
    Yes but your speaker choice is extremely limited. Both the sub and the speakers would need to run at the same impedance which with speakers is generally 4ohm and you're limiting what speakers/subs you can buy as they'd need to match up in power specs for optimal performance (and most subs are atleast 150wrms, which puts the price of the speakers up also as not many lower end models are rated that high. But at the same time if you get an amp that puts out 50wrms which is the same rating as the speakers, its not really sufficient for a 150wrms sub).
    Rear speakers are only really for rear fill, so sound quality is not a massive issue and neither is volume. They will run decent off the headunit providing you have a MOSFET 50x4 headunit of alright quality.
    You could look at a 5 channel amp (not sure what Jaycar offer there) and then get some good front speakers for sound quality, some cheapy rears and a decent 10" sub that can all be run off the 5 channel amp.
    VZ Clubsport
    Oct 2007
    Busselton, WA
    hey just had a look at you ride and do you have a factory deck? or a aftermarket deck.
    VYII SV8
    Aug 2006
    Toowoomba
    The Jaycar Precision Response 4x50 amps are a great little unit, and do a fantastic job of powering a sub and 2 speakers.
    Bridge 2 channels to run the sub, and replace and amplify the front speakers. Leave the rear speakers to run off the head unit, you don't need them to be loud. There's a bit of work in running the wires, but it's a very simple matter to connect it all up.
    Obviously it's not going to give you competition performance but it will be an enormous improvement over factory.
    1991_Vn2nV's Avatar
    Mar 2006
    Just ensure the speakers and sub are all running at the same ohmage (is ohmage a word?). I.e. all are 4ohm.
  1. Factory Reversing Alarm System
    By Calaber in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-06-2008, 10:52 PM
  2. upgrading 202 to Vn V6
    By V-ahhh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-12-2006, 06:22 PM
  3. Upgrading my system
    By nath_120 in forum Car Audio
    Last Post: 31-10-2006, 06:31 PM
  4. factory system question..help please!!
    By Lish in forum Car Audio
    Last Post: 04-12-2005, 01:51 PM
  5. VS Calais (factory) 8 speaker system
    By Fletch_QLD in forum Car Audio
    Last Post: 16-09-2005, 03:48 PM
