Results 1 to 3 of 3
Thread: VS Double Din??
    ezytarget Guest
    Default VS Double Din??
    Hi,
    Recently i purchased a LCD 7" in dash screen and I am planning on purchasing a DVD/VCD receiver in the near future... however before purchasing the screen I had'nt put much consideration into how i would get 2 head units (including the screen ill refer it as a head unit because it has the same mounting specs). Basically im looking for any suggestions at this point, but there are a couple of factors....
    1. I dont want to have to cut the stock facia as i plan on re-installing all of the stock audio equipment when I eventually sell the car.
    2. I have also checked aerpro's catalogue, i cant seem to find what im looking for unless i have missed it.
    So basically, what i am looking for is a double din conversion from the vs commodore's single din any suggestions would be greatly appreciated!
    Thanks
    ElMiNsT3r Guest
    well, id say ur best bet is to buy a plastic cover thing the one that goes over the radio, and cut into it and put the screen in the LCD in the radio spot and put the player in the place were the little dash pocket thing was ive seen a few pics of them n by the sounds of it they fit, just b4 u do it check if it does b4 chopping stuff up...hope that gives u some ideas..
    Blown VS Calais !!
    Jan 2005
    Kalgoorlie WA
    You CAN NOT fit double DIN into VS , you can however fit 2 DIn units in , you will need to source another facia as there is no way around it but to cut the bottom tray out.
    If you havnt done an install before pay someone proffesionally to do it as it is not an easy job.
    Right click save as . .
  1. vz double din
    By scolari in forum Car Audio
    Last Post: 21-10-2007, 04:40 PM
  2. I'm double posting :S
    By matty88 in forum Site Feedback / Site Problems
    Last Post: 30-09-2007, 02:57 PM
