Results 1 to 7 of 7
Thread: high pitch sound
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Default high pitch sound
    im getting a high pitch winding sound from my rear speakers connected to the amp sometimes.. whats causing this?
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    VY2 Berlina
    Jun 2008
    Castle Hill
    CANYONERO's Avatar
    CANYONERO is offline Likes Cheese...
    V8 6spd wif MOMO leavaa.
    Mar 2006
    Country SA
    i got the same thing, when its loud enough i cant hear it. lol. thats my current fix. try cleaning your earth point? i also have rear speakers amped. lets know if you find a solution.
    Goon's Avatar
    Feb 2006
    GC. QLD
    Yeah i suspect its my connections, i disconnected the rear speakers and go better bass and sound as i did it with the amp still connected..
    I'm going to play with the gain settings on the amp to, i think its set to subwoofer
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Give some decent information, like what equipment you have and how it's connected.
    Farlig's Avatar
    Farlig is offline Donating Member
    Y-Series Clubsport
    Jan 2005
    if the sound is only evident when the vehicle is running, usually its engine noise. common fixes are better earth cable for battery, better route for the power cables, separate the rcas and power leads for amps as much as possible, install noise suppressors "ground loop isolator" on the speaker rca's at the front or the rear of the run, improve amp earth points by sanding the mounting area back for a clean contact. use higher grade cables etc.
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Google "ground loop".
    PS. Eliminating the ground loop will give you much better sound than "filtering" it.
  1. Sound System high pitch sound
    By liquidforce_134 in forum Car Audio
    Last Post: 16-07-2008, 10:31 PM
  2. high pitch squeeling at high speed
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-02-2008, 09:29 PM
  3. High pitch noise @ high rpm
    By Jesterarts in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-11-2007, 10:00 AM
  4. alternator high pitch noise
    By nick88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-10-2006, 05:23 PM
  5. High Pitch squeal
    By Phoenix21 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-08-2006, 06:18 PM
