Results 1 to 6 of 6
Thread: sub direction
    benny mckellar's Avatar
    benny mckellar is offline boobs,blowers,burnouts
    vr ute
    Mar 2008
    Default sub direction
    hi i'm puttin a sub in my vr ute on the weekend im puttin it next to the fuel tank and was wondering if the direction its facing matters to face forwards the sub is exposed to dust and stuff but if it faces backwards its safe does the direction matter
    Haydz's Avatar
    Haydz is offline 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    Bass is not directional if thats what your wondering. so it shouldn't make any difference facing it either way.
    try it both ways and see which you like better
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    It is personal preference, so try both and see how it sounds and what you prefer.
    Going on the dust etc. i'd probably face it backwards I guess in your vehicle. As above, bass is not directional and below 100hz the human ear isn't meant to be able to tell where the bass is coming from (depending on where your filters are set to the sub probably shouldn't be playing above say 80hz). So it shouldn't matter what way it is facing. However, after saying that... You will notice a difference depending on what way it faces for some reason but what is better is up to you.
    Sep 2007
    I reckon faciing it backwards you produce more bass as it will vibrate through the car..
    Try it both ways see which way you think is the best
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    yeah if you can facing it backwards will produce more bass, as it creates a "loading" wall using the panel it fires against. If the box is going to be sealed (more than likely) then i would leave around 10-15cm gap in between the subwoofer and the panel to allow for the bass to circulate. If its ported than leave say 20cm or more if possible.
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Direction can make a difference, if it faces back the sound will take longer to get to your ears, which depending on the setup and application can be better/worse. Like others have said, try each for a few days and see!
    Also make sure the +/- are done correctly, otherwise it will be out of phase with the other speakers, which again can affect the sound.
  1. Sub direction in boot.
    By And_ROOS in forum Car Audio
    Last Post: 20-03-2008, 01:05 AM
  2. Best direction to place a sub ????
    By COINERS in forum Car Audio
    Last Post: 16-06-2006, 10:31 AM
  3. Which direction
    By G4orce in forum Car Audio
    Last Post: 11-08-2005, 08:48 PM
  4. help to go in the right direction....
    By Slow_Az in forum V6 Development And Modification
    Last Post: 08-07-2005, 03:05 AM
  5. Air Con Direction
    By death-from-above in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-01-2004, 03:44 PM
