Results 1 to 12 of 12
Thread: amp????
    SAV_117's Avatar
    SAV_117 is offline Donating Member
    VY Lumina
    Jul 2008
    Question amp????
    i have a question were does everyone hide the wires for there amps and if its under the seat how???? if u guys wouldnt mind could i have some pics thanks
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Where the seat bolts to the floor there is holes in the carpet, feed the wire through those and then be careful when putting the seat back in that you don't crush them.
    SAV_117's Avatar
    VY Lumina
    Jul 2008
    ahh didnt think of that thanks how would u bolt it to the floor like wat would u use or did u use
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Some people put a bit of MDF under the carpet and screw through the carpet into the MDF. Others use velcro on the bottom of the amp and it just grips to the carpet. I'm sure there's other ways as well.
    SAV_117's Avatar
    VY Lumina
    Jul 2008
    i like velcro cause i got some here haha thanks would u suggest this or in the boot and if in boot were would u mount it
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    It's up to you... Under the seat is well hidden, but can be damaged by careless back seat passengers kicking it. In the boot it harder to find a flat surface out of the way and you need more cabling and you have to pull more of the car apart, but it's less likely to get damaged.
    I always use the boot as I like to able to adjust my amps easily if needed.
    VY SS
    Jun 2006
    Albany
    ive got 2 amps 1 under each seat, for the wires i just cut a small hole in the carpet and fed the wires through that as for mounting them mine are just sitting there they don't really move around so im not worried. if my amps were more expensive i would of mounted them in a better way but at the moment i only got a couple of cheapies
    SAV_117's Avatar
    VY Lumina
    Jul 2008
    SAV_117's Avatar
    VY Lumina
    Jul 2008
    still thinkin on were i should mount it cause i dont want all the wires showing im leaning toward the boot at the moment
    LightningVP is offline Donating Member
    None
    Sep 2008
    Quote Originally Posted by DJS_117 View Post
    As for the cable showing problem, there are ways of making it look good...wrap all the cables in electrical tape, or you can use the black cable tubes...But I have mine in my boot at the moment, which is screwed into the floor behind the back seats...
    SAV_117's Avatar
    VY Lumina
    Jul 2008
    ohh i didnt think of that thats a good idea it would look much neater thanks
    None
    Sep 2008
    No worries, glad I could help
