Results 1 to 13 of 13
Thread: engine whine
    FULLY TURBO vw caddy van :(
    Jul 2008
    Castle hill
    Default engine whine
    Hey guys,
    What are the reasons why engine whine could occur in a single speaker??
    I'm running my RCA's and speaker wire down the passenger side and power down the drivers
    Nothing in the boot is clashing.
    Yet my front left speaker has engine whine.
    Any ideas?
    VY SS
    Aug 2004
    SE Victoria
    swap the RCAs into the amp. this will assist to determine if its after or before the amp.
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    engine whine as in the whine on the speaker increases with engine revs?
    Had that problem in mates xr ute and it was due to poor grounding
    no longer a hoon by association - the commodore is gone
    Jul 2008
    Castle hill
    Quote Originally Posted by nicko View Post
    Yeah thats right, increases as i increase rev (very annoying)
    Poor grounding on what? the amp? loose wire on the speaker?
    Only thing i don't understand why it would be only on 1 speaker..
    You'd think it would be on the front channel (so both front speakers)
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    grounding on the amp fixed it for us. have a play with a different grounding point
    Jul 2008
    Castle hill
    Alright I'll give it a go
    I'll and ground it somewhere else, at the moment its grounded under the rear passenger seat, maybe someone has knocked it out of wack very possible.
    Thanks
    commsirac is offline Banned
    vx
    Aug 2007
    I suspect a problem with the rca lead going to that channel of the amp. did you swap them over as suggested?
    Jul 2008
    Castle hill
    Quote Originally Posted by commsirac View Post
    Na not yet, i'll have to give it a go tomorrow...
    i've also noticed my rear left speaker is very distorted! damnit
    wondering if the problem is part of that too...
    Jul 2008
    Castle hill
    I tried swapping the RCA's out, just got some spares and ran them straight down the middle. no success. I re-earthed the amp. still nothing.
    I've been told JBL amps are known to do this...
    I have noticed that it's not distortion and its just ALOT of engine whine coming out of the rear left speaker. So it's the entire left side of my car
    VY SS
    Aug 2004
    SE Victoria
    vx
    Aug 2007
    Quote Originally Posted by Timmos View Post
    So you also changed over the leads to the speakers? and the noise is still in the left speaker, or does the noise change over to the right speaker, indicating that the same channel of the amp is somehow affected. If the latter, definitely a problem with your amp.
    Jul 2008
    Castle hill
    So i've still got engine whine after getting my amp back.
    Question i should of asked before, Is there enough current going through the REMOTE cable to cause engine whine?
    If not i'm suspecting a faulty Hi-Low converter.
    Luke0011 is offline Car Audio Installer
    VZ Berlina 2005
    Jan 2007
    ive have noticed on occasions that the location of the crossover can cause static in one speaker dpending on where its located. Try moving the crossover and see if that removes the static.
  1. VN-VP whine
    By GreendragonDMX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-09-2008, 12:58 AM
  2. Engine Whine
    By KLatham in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-06-2008, 08:23 AM
  3. Engine whine
    By ghoul in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-02-2007, 12:50 AM
  4. Whine in back end
    By inwiththenew in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-07-2006, 09:21 PM
  5. VY SS Gen III Engine Whine?
    By VYSS346 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-01-2006, 10:05 PM
