Results 1 to 6 of 6
Thread: 2005 VZ Executive Stereo Questions
    '05 VZ Exec
    Sep 2008
    Gold Coast
    Default 2005 VZ Executive Stereo Questions
    Hi guys i'm looking to install a new stereo in my VZ just have a few queries i hope you might be able to help with.
    I'm planning on getting a Sony Head Unit MEXBT2600. i already have an amp and sub the amp is a Blaupunkt Velocity 800W 4 ch and the sub is a Kenwood 12" 800W.
    1. Now the head unit is a Single din and i have seen aftermarket cradles around just nned to know if they are any good and any mounting issues if possible.
    2. The antenna is electric and i still want it to function the same i.e it only goes up when the radio is on and retracts whenthe radio is off. what will be required to keep this function do i have to work in a switch of some kind ect.
    3. will the radio staying on till i open the drivers side door still work with aftermarket head units? and will it light up like the stock unit does when i unlock the doors ect.
    4 Suggested Amp mounting solutions and suggested places to mount without drilling the crap out of my boot.
    5 Suggested ways to run the wiring.
    I'm sure i'll have other questions later thanks in advance for your help.
    '05 VZ Exec
    Sep 2008
    Gold Coast
    Also whats the possibility i'll encounter error messages on the indash screens(computer)
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    no errors on the dash, unless some thing is something has been stuffed up
    1, yes the cradles work good, ive found you need to slightly round the lugs that hold it in with a file so it makes it easier to remove if needed
    2, if the head unit has a antenna output, use that, if not, use the 12volt out switching wire for the amp, and as you said you will need to wire in a switch so they antenna will go down when a cd is playing
    3, yes, it will light up if the h/u has an illumination circuit
    4, inverted under the parcel shelf
    5, use a bare euro plug and solder that to the harness that comes with new h/u, so you dont have to cut the factory wiring, you can re-install the factory unit then if needed, if you use the euro plug check the wire pinouts are correct, the accessories and constant where around the wrong way in mine. the plug pinouts picture is stuck to the top of the factory h/u
    run power under one of the sill covers, and run the rca's down the other.
    oh and good to see another Barbados vz on here
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    '05 VZ Exec
    Sep 2008
    Gold Coast
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    The plastic cover on the doorway... Where the sill is... The plastic between where the carpet meets the door.
    Hope that makes sense.
    '05 VZ Exec
    Sep 2008
    Gold Coast
    Yeah i thought thats what you mean. I refer to it as the plastic **** near the door thought so was a lil confused when you said sill :P
  1. Cold Air Induction for 2005 175 Executive
    By Crabito in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-12-2007, 07:54 PM
  2. VZ Executive, some quick questions
    By RichoVZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-10-2007, 11:32 AM
  3. My VY executive - Clubby Kit, Senator Bobtail, Alpine Stereo
    By Saitimus in forum VY - VZ - WK - WL - V2
    Last Post: 07-05-2007, 02:15 PM
  4. VR executive questions
    By stocky in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-06-2005, 11:58 PM
  5. Vs Ute Stereo Questions
    By Troy711 in forum Car Audio
    Last Post: 15-01-2004, 12:01 AM
