Results 1 to 9 of 9
Thread: extra wires
    VR commodore exec
    Oct 2008
    Default extra wires
    hey guys, i recently got myself a vr commodore, and have bought a new head unit for it since the old one was cactus!
    i have spent a few hours on it and putting cables together but from the car i have two spare wires which i dont know what to do with, the deck is turning on and functioning but im getting no sound out of the speakers.
    ive looked through all the wiring posts i could find and there was no black/white wire! is my car a freak?
    the cables i have left from the car are a black/white one
    and a brown and white one which is illumination but im not sure where im supposed to put it.
    from the actual head unit there is a blue/white wire with a plastic clip at the end.
    ive uploaded pics so u guys can see what im talking about. i hope this is enough info for a good explanation why im getting no sound, and what do to with these spare wires.
    also where is a good place to connect my earth cable from the unit, its like a U shape, so im guessing it can go behind a screw or something any ideas will be greatly appreciated. thanks in advance!
    [IMG][/IMG]
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    From memory, the illumination wire doesn't need to be connected. The lights on the new headunit will just be on all the time.
    The blue wire on the back of the new unit is the remote wire for connecting amps etc. This isn't used if you aren't running an amp.
    Black and White wire...is that the earth? I used the factory earth for my CD player, or there should be a screw you can attach it to down the passenger side of the console I believe.
    As far as the no sound problem, are you testing the headunit as shown in those pics? At least wrap some tape around the connections if you don't want to solder them until you are sure they will work. Looks like the speaker wires are probably shorting.
    Apart from that, someone else can probably post up some more ideas
    If you need I'll take a pic of the wiring for my CD player tomorrow since it's already out
    VX S2 Exec
    Sep 2008
    conenct the blue wire to the electric antenna if you have one, I will send you wiring info tomorrow out of the manual if you havnt sorted it by then as to what the factory wires are for the speakers
    VR commodore exec
    Oct 2008
    great news, i taped it up this morning and it worked!
    now to solder it and i'll be on my way woo!
    thanks for the help, the cars earth and illumination will be hanging around with nothing, is that fine?
    hakhawk's Avatar
    hakhawk is online now smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    tape up the illumination wire at least, if it shorts, it will probably blow the fuse, leaving you with no dash lights and such, and it will only take a second to tape up
    VR commodore exec
    Oct 2008
    yeah i taped both the illums and earths ends up
    now for front splits and tweeters!
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    your car may have a common earth on the front speakers. (weird setup my vl had that) had to run new front speaker wires
    ========My Statesman 20's Mafless and 3.9's========
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    wont be common earth pre vls were not vn onwards
    you say ya cant find the black/white then you say ya have a black/white left over that is ya earth
    if you gont earth the black wire from cd player youll be getting earth from your antena socket so earth ya black wire youll be fine
    just make sure no spkr wires are grounded or youll get lights but no sound
    VR Statesman, WK Statesman
    Aug 2006
    This should help
    Attached Files Attached Files
  1. Extra Go....
    By Jenga73 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-11-2007, 04:21 PM
  2. need extra
    By VG commodore ute in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-10-2005, 03:45 AM
  3. Extra grunt SS
    By Dinga in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 17-09-2005, 03:24 PM
  4. extra 200 CFM of air on V6 models
    By sp001in in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-07-2005, 11:18 PM
  5. Extra Gauges
    By menzy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-12-2003, 05:40 PM
