hey got another problem again i got a fuse an wiring but now i cant find a spot to run the dam fat red wire through the firewall i dont wanna huck it up or really drill a hole in the firewall just been repainted the whole car an i dont wanna run it out the passengers side an around the back side off the engine didnt get that much wire so how u guys normally run the constant 12v power wire![]()
In a VN, if auto there is a spare grommet where the clutch cable goes. In a manual there is a grommet next to the brake booster, need to remove washer bottle to get to it.
cheers.
yeah i see it choice man thanks quick reply will it blow heaps cold air though there tho
Punch a hole through the rubber grommet and run the cable through it, so its sealed and no air or water can enter.
