Hi Guys, just finishing up the last of my sound system in my VS Wagon, I've found the clutch grommet and fed the 12V cabling through it, but i can't find where it came out on the inside of the car, do I have to remove the dash?
No you wont have to remove the dash. You need to remove the black plastic cover under the fuse panel that goes around the pedals. Then if you look up under there you should be able to see where all the wiring harness goes through the firewall through a black rubber grommet. Then roll back the heat proof floor lining (dark brown rubbery carpet stuff) that extends all the way up to the dash and you should be able to see your power wire just to the inside of the main harness. Hope that made sense and helps.
