Results 1 to 7 of 7
Thread: Electric Antenna Doesn't Extend/Retract With Radio
    VP Vacationer
    Nov 2008
    Unhappy Electric Antenna Doesn't Extend/Retract With Radio
    Hi, I just removed a broken electric antenna from a VP Vacationer I bought and replaced it with a working one. The problem is it wont extend or retract when the radio is turned on/off, it remains down. On a kind-of-good note it extends when i hold the extend ant. button on the cruise control unit but as soon as i let it go it retracts itself, hmmm. PLEASE HELP ME.
    Thx Les...
    VX S2 Exec
    Sep 2008
    depends what kind of headunit your running, if it is aftermarket you will have a blue wire output that needs to be hooked into the antenna circuit,
    im not 100% sure with the factory unit but im sure it is something similar
    VP Vacationer
    Nov 2008
    Yeah, it's an aftermarket JVC MP3 CD Head Unit. The antenna has a red and white cable as well as a black one that runs into itself a ground cable that screws to the side of the car and a coax cable.
    Also, any ideas why it wont stay up when i let go of the extend button on the cruise control panel?
    Thx Again Les...
    SAV_117's Avatar
    SAV_117 is offline Donating Member
    VY Lumina
    Jul 2008
    no idea why it wont stay up but like RC said there is a blue wire on the headdeck are u sure u put everythin back in the way it was before when u put the new one in???
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Was the antenna you replaced from another VP?
    Sounds like a wiring problem.
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    This happened to my grandfathers stock Vacationer VP. I havn't been able to check it out for him yet, but it seems to either be a loose connection at the rear of the unit or the power antenna itself (or a broken resistor according to him)!
    VP Vacationer
    Nov 2008
    It was actually a electric antenna from a VQ Statesman but I'll check the setup at the back of the head unit. If there is a blue wire do I need to pull the antenna apart to connect it?
    Thx All...
  1. Electric Antenna installation on standard/non Electric ant VN/VP
    By AlpineRaven in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-09-2011, 03:38 PM
  2. VT Radio Antenna
    By Hubba in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-01-2006, 12:16 AM
  3. Disconnecting radio antenna/aerial
    By CLE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-11-2005, 11:19 AM
  4. Vp Commodore Radio Power Antenna
    By Abe in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-05-2005, 05:53 PM
  5. Vp Commodore Radio Power Antenna
    By Abe in forum Site Feedback / Site Problems
    Last Post: 02-02-2004, 03:43 PM
