Results 1 to 18 of 18
Thread: VE Head unit replacement.. PLZ HELP
    VE
    Nov 2008
    Default VE Head unit replacement.. PLZ HELP
    First post here .. need some help
    my car is australian made 2008 chevrolet lumina SS head unit is same as ve commodore SS but it came without DVD screen and it's all linked together with climate control as in this picture:
    I need to replace my head unit with another one with DVD as well as climate control like this:
    Can anyone suggest where you can get a head unit online?
    VE
    Nov 2008
    2010 Isuzu FXZ 1500 on 20's
    Oct 2006
    Bogan enclave
    VE
    Nov 2008
    Quote Originally Posted by Bravotwozero View Post
    Not sure mate.
    But you could try emailing sales@holmart.com.au they may be able to help you out.
    Home
    thanx mate ... already checked with Holmart nothing yet
    elemeNtz is offline It's my first day :3
    responsibly
    May 2008
    VE
    Nov 2008
    Quote Originally Posted by elemeNtz View Post
    call holdens?
    need to buy it online ... am overseas
    Luke0011 is offline Car Audio Installer
    VZ Berlina 2005
    Jan 2007
    Its not worth doing, unless you want to spend big bucks replacing the whole wiring loom in the car as the climate control uses sensors extra wiring etc, as well as a diferent heater box. Very expensive and also the climate control switches as well as buying the factory DVD screen. It could cost up to 6 grand . I would just trade in the car and buy one with the dvd screen and climate.
    VE
    Nov 2008
    Quote Originally Posted by luke0011 View Post
    thanx for the advice .. But I think I won't need to change anything except the front board which contains all the buttons .. Because I removed it once and it was just a cover or face board which contains the buttons and it is then connected through a port with the main unit and CD changer..plz advice if it is different with VE
    VZ Berlina 2005
    Jan 2007
    no its completely different, YOur chev SS dos not have climate control. The DVD screen will plug into your vehicle, but will not have the extra video, nav wiring in the iso connector.
    VE
    Nov 2008
    alright thanx Luke .. but I really don't like my headunit do you know anyother aftermarket or replacement Head Unit which can fit my car?
    VZ Berlina 2005
    Jan 2007
    You can fit any single din, or motorised single din screen headunit directly under the heaters controls. although you have to remove the heater vent going to your rear console. But hey its your car, buggers the passengers
    VE
    Nov 2008
    thaanx for ur advice mate .. I am looking for some head unit which will fit my car with all these like what in VE commodore .. I don't want to fix something and keep the head unit
    so I will keep looking
    VZ Berlina 2005
    Jan 2007
    you can easily fit an aftermarket head unit into your ve and then pull it out. you will only have to buy a new rear heater vent.
    VE
    Nov 2008
    but I need to make it fit in the same place where my original head unit is placed
  15. #15
    VZ Berlina 2005
    Jan 2007
  16. #16
    VE
    Nov 2008
    YOu cant make it fit in there, just fit it underneath.
    OK I will try to do so .. thanx
  17. #17
    ve Omega 2008
    Mar 2010
    Default head unit replacement...
    Quote Originally Posted by Luke0011 View Post
    hi, i installed new amp and subs in my omega,i spend heaps on it but not really satisfied....i hate factory fitted headunit, could you please teach how to put new after market headunit and where...
    regards,
    Perry ve
  18. #18
    VE BERLINA 07
    Jan 2011
    Rowville Melbourne Vicotria
    jhp do it but its expensive.
    what i would love to know is if i have a berlina unit the faceplate can it be changed with the calais head unit faceplate since there the same ones coloured and ones green
    I'm a boy who appreciates a good body, regardless of the make.
  1. battery replacement in vs key head
    By carpetsnake in forum General
    Last Post: 18-11-2008, 06:12 AM
  2. Replacement head unit. VS caprice
    By coolngroovy in forum Car Audio
    Last Post: 01-06-2008, 09:42 PM
  3. VR Head Gasket Replacement
    By boogs86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-06-2006, 09:07 AM
  4. VR Head Gasket Replacement
    Last Post: 01-06-2006, 06:33 PM
  5. Vn Head Gasket Replacement
    By James Collins in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-12-2003, 07:18 PM
