Results 1 to 7 of 7
Thread: Help vt sound system
    VT Executive
    Nov 2008
    Default Help vt sound system
    He im a new member. ive been reading some stuff and i got really into sound and i wanna fix up teh vt but im confused.
    i ahve a slot fo subwoofers i dont know what to use i have
    cerwin vega 2 12" s
    sansui 12's again 2 of them
    and some magic sound 15's
    i duno what to use
    adn what amp du i need . ive been hearing about this thing called a mono block what is it?
    i went in to strathfield and bargained a guy down for a head unit adn some 4way splits and a xplod deck
    CDX-GT670U : Xplod CD Receiver : Car & Marine Entertainment : Sony Asia Pacific
    Sony XS-GTX1640 6-1/2" Full Range 4-Way Speakers
    can u help em out he want $400 for the ceck with 2 sets of speakers is this good? im plainning to run 6.5's in each door
    and 2 12's or 2 15's in the boot.
    duno if its good
    helppp
    thank you
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    depends on how many subs you wanna run and how many amps.
    a mono block i believe is a single channel dedicated to a sub.
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    thats correct a mono block amp is a single channel output amplifier and is primarly used and aimed at powering subwoofers. Out of the ones you have, definetly use the Cerwin Vegas without a doubt, I don't care if they a falling apart...use them!
    Luke0011 is offline Car Audio Installer
    VZ Berlina 2005
    Jan 2007
    Well for starters, your typing isnt that great but i get the jist of it. Anyway The Cerwin Vega has a stronger reputation than Sansui, but both are good brands. If you want to get noticed, use the two 15 inch subwoofers, with a minumum of 500 watts rms of mono block amp power. Although your boot will rattle a bit. I would probably go the 2 Cerwin Vega woofers. and in my opinion run speakers in the front doors and rear parcel shelf. No need to have speakers in the rear doors. The sony unit is fairly decent with a 24 bit DAC, so 400 isnt that bad.
    VZ Executive
    Nov 2008
    I would go the Cerwin Vega subs, prob only the decent brand of subs you have, as for speakers forget rears spend all the money on fronts, rears are only for passengers and they sure didnt pay for your system so why spend money on them. as for HU no experience with that HU in particular however I tend to always steer clear of Sony, perhaps look inot Eclipse or Alpine. heck I would even choose Pioneer over Sony.
    as for amp a mono would be best, however you need to match the amp to the subs you use. no point using a mono that produces best power at 2 ohms if you have dual 4 ohm subs as you wont be able to utilise this power.
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    The speakers you have linked are just co-axials so just get one set and run those on the rear shelf. Get some 6.5" splits for the front.
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    That Sony gear is pretty much entry level brand name stuff - I'm not saying it's bad, it'll be a big step up from the factory gear, but with car audio you can spend as much or as little as you want. The further into the future you plan, the more you're likely to save in the long run by not buying gear, then replacing it 6 months later with better gear.
    If you're just after something alright which can go a bit louder than the factory stuff, then that setup should be fine. If you want super loud, or really high quality sound, you might want to think about spending a bit more.
    Like vn2nv said, get splits (if you can afford it). They cost more, but sound much much better because you get better sound staging, and usually better power handling.
    Also, as mentioned, try to use proper spelling and grammar, it makes it much easier for people to understand you. People are giving you help and advice for free, its the least you can do.
  1. Sound System high pitch sound
    By liquidforce_134 in forum Car Audio
    Last Post: 16-07-2008, 10:31 PM
  2. VY sound system
    By Loupy31 in forum General
    Last Post: 10-05-2007, 09:49 AM
  3. sound system
    By matt_gotigers in forum Car Audio
    Last Post: 18-07-2006, 08:30 PM
  4. FS: VX with $10,500 sound system
    By paulio in forum Parts And Other Items For Sale
    Last Post: 02-03-2006, 12:52 PM
  5. just bought sound system, will it sound good
    By pier_one in forum Car Audio
    Last Post: 02-10-2005, 01:27 PM
