Results 1 to 5 of 5
Thread: Headunit connection help
    hitch hiker
    Oct 2008
    Default Headunit connection help
    Just abit of help would be greatly appreciated. I had a suss at the sticky headunit guide and the pictures didn't show up on neither my computer, nor my brothers so it was abit hard understand seeing as I don't know that much about car audio.
    I'd rather do it myself instead of paying someone too install it as i'd rather not waste money on having someone installing a headunit.
    I've got this kenwood headunit (KDC-x7529.. its got a motorised/detachable headunit) i'm looking at putting in, but when I removed the stock eurovox head and tried placing the new one in, I found the connections were wrong. How do I go about changing all this over? Is there anyway I can take the easy way out like getting add-on connections that slip into the old ones at one end and go into the new ones at the other?
    Or do I need to go deeper and take apart wires and solder stuff etc etc
    I have a VP Lexcen by the way
    Thanks
    Attached Thumbnails Attached Thumbnails Headunit connection help-connection.jpg   Headunit connection help-new-headunit.jpg   Headunit connection help-old-headunit.jpg
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    go to autobarn or motoquipe and ask for a adapter for a vp commo to kenwood deck.
    or if ur in s.a sling me a 5L keg or german beer and custom wire it
    SIR LS1
    the two ton go kart
    hitch hiker
    Oct 2008
    Yeah cheers mate, I must just do that. I'm guessing the connections for the Lexcen are the same as the commmodore?
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    VP Calais
    Oct 2008
    doubt you will find a vp to kenwood specifically. The patch loom will have open ends then you will have to wire them according to the kenwood manual the came with the radio.
  1. wire connection
    By dijm8 in forum Electrical Wiring / Questions
    Last Post: 09-03-2007, 11:14 PM
  2. Amp connection
    By myhsv in forum Car Audio
    Last Post: 06-09-2006, 08:18 PM
  3. Old headunit versus New Headunit
    By SVZ_MY06 in forum Car Audio
    Last Post: 28-04-2006, 11:12 AM
  4. Gen 111 connection to Laptop
    By Chester in forum Electrical Wiring / Questions
    Last Post: 02-10-2005, 07:37 PM
  5. VT ECU connection to laptop
    Last Post: 28-09-2005, 08:56 PM
