Results 1 to 16 of 16
Thread: VS Ute - Front Speaker Pods - 6.5"
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    Default VS Ute - Front Speaker Pods - 6.5"
    Hey guys sorry if this has been posted but i need some info asap hopefully before tomorrow. Well i have a Holden VS Ute and am looking at replacing the front door speaker pods with hopefully some Alpine S Type 6.5 SPS-600
    Alpine Electronics of Australia
    Although before purchasing these tomorrow i am just looking for confirmation that 6.5" speakers do fit in the 6" standard pods? If so does this require any modification because i would rather not be cutting/sawing any plastic etc. I was hoping someone with a VS could share some info on this matter as well as the speakers i intend on buying? If so do they just slot in like the standard speakers or are they to wide/deep etc? If this is the case can anyone recommend any 6" or 6.5" speakers that will fit as i really liked the look and sound of the Alpine S Types along with the S Type Sub.
    Any links or guides preferably with photo's of the install with problems etc encountered would be much appreciated.
    Thanks
    Matt
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    I would imagine you would have to cut a small amount of plastic out of the speakr mounts to fit the Alpine speakers, it isnt too much trouble...and you can always buy another set from a wreckers if need be. They should fit depth wise, but you may have to cut the back panel that holds the stock wiring, all of which is part of the plastic speaker mount.
    There are a few brands of 6" (not 6.5") speakers available, if you wanted to go with a set of component speakers (splits - HIGHLY recommended) then Jaycar make a set that definately fit right into the standard mounts - Cat # CS2327.
    VS Maloo
    Jan 2006
    Hawkesbury
    Im guessin theyre the same dimensions as the Type R's. I had Alpine type R speakers in my VS and they just went straight in, no modifying watsoever. (i dont know if the guy before me had speakers but it didnt look like it.
    My mate had the type S speakers, and they go decent enough too.
    --APOC--
    Aug 2008
    Quote Originally Posted by apoc585 View Post
    Thanks for the replies guys, would these speakers be the ones you mounted in your VS by chance? Alpine Type R SPR-17C
    Because they look the same size as the Alpine Type S speakers that i will hopefully be purchasing. Only problem is on the alpine site the type r has dimensions but the type s doesn't so i cant be definite. Could you contact your m8 and ask him quickly if he has a commodore?
    EDIT: K just found some more info, so did you say you had mounted the Type R Alpines in your commodore because if so does that mean according to the info below that the S Type Alpines should fit?
    Alpine S Type SPS-600 - 6.5" Coaxial
    Manufacturer Part Number: SPS-600
    # Woofer Mounting Depth: 56mm
    # Woofer Mounting Diameter: 125mm
    Alpine R Type SPR-17C - 6.5" Coaxial
    Manufacturer Part Number: SPR-17C
    # Woofer Mounting Depth: 63.2mm
    # Woofer Mounting Diameter: 135.2mm
    Anything else i should be aware of size way that may not fit? Also just to add i dont need any of those tweeters or splits etc so Coaxial should be fine right? Thats just the two speakers right? As i cbf mounting tweeters etc and my stock VS Ute Speakers would just be stock Coaxial right? Just two stock speakers not this high class component stuff with tweeters etc?
    Thanks again and i hope i am making sense.
    Matt
    VS Maloo
    Jan 2006
    Hawkesbury
    yea man. plenty of sense made! haha
    ok my mate lives next door, i install all of his stuff cos i enjoy playing with sound systems, so yes he has a commodore(VY Ute).
    If i were you, id replace the tweeters n crossovers too cos it will sound much better and realistically its not that hard. if you wanna run a sub too i'd get a decent 4 ch amp and run the speakers n sub off that and you will have a mad system setup without burning the budget.
    Youve certainly chosen a great product so as long as you dont go E series alpine, you will be alright.
    ps. yes im biased towards alpine as i have r series splits and subs and alpine V12 amps. haha
    --APOC--
    Aug 2008
    Alright sweet but one question are you saying that the stock VS Ute i have has got separate tweeters or that the tweeter is built into each door speaker pod? Because i just want a simple easy install and the current stock setup from factory already suits my fancy except for the lack of bass which the sub should fix and maybe slightly better quality audio overall.
    Also you must of read my mind as i am hopefully purchasing the
    Alpine MRP-F600 AMP
    To go with the
    Alpine S Type SWS-1043D SUB
    And speakers which you already have heard about. Also the reason i am sticking with Alpine is for the quality which my father and i both have been pleased with along with the fact i may be getting these items at cost price.
    Now the S Type Speakers that i am hopefully purchasing have the tweeter built in right which i feel sure will be fine for me as i dont want to be messing around with component speakers that have separate tweeters as to me its to much work and i like to keep my equipment in my car half sensible if that makes sense
    Would you be able to tell me what this crossover stuff is? and also if the Speakers/Sub and Amp i have selected will suit each other and get along, such as below it seems to me they should be ok and give the Speakers and Sub the power to reach their full potential?
    Speakers are 80W RMS x 2 and the Amp is 4 x 100W RMS = Good?
    Sub is 300W RMS x 1 and Amp is 2 x 300W RMS = Good?
    Thanks again
    Matt
    VS Maloo
    Jan 2006
    Hawkesbury
    sounds like ur over doing it with the amps. you only need a 2x100W rms amp to run the speakers. it gives u 20Wrms leeway which in all honesty is heaps as long as ur not cranking it at full pelt all day every day
    A crossover basically gets a signal and splits it into high and lower Freq's, the lower freqs will go to the speaker, and the higher will go to the tweeter. the tweeter in a vs is located on the dash at the bottom corner of the windscreen. it can be difficult to get to at times but if you want a decent sounding system its worth it. the cover is in 2 pieces, its split in the centre. in the pic below its the black mesh part, but in a stock car it'll have a grid. (same position though)
    --APOC--
    VS Maloo
    Jan 2006
    Hawkesbury
    sorry have read all this wrong...
    get alpine s series splits!!! not speakers. they're 6 inch so they fit right in, and if you put the crossovers n tweeters in it'll sound way better!
    sorry about that. i read it wrong
    --APOC--
    Aug 2008
    Ah hell i never knew they were there. Well as for the amp there isn't really anything else that covers what i need for the Amp and Speakers such as 100W x 2 and 300W x 1. Also if you mean the Alpine S Type SPS-600C thats still 6.5" not 6" according to their website.
    Last of all how hard is it to install the tweeters? Very hard or just very annoying and time consuming etc?
    Are the crossovers run in the Amp to each speaker/tweeter if i get splits or is this another external piece of equipment needed?
    Thanks again
    Matt
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    The Type-s coaxials will fit straight in *just*. I had them, and with the old style ones I had to bent 1 of the tabs that you use to screw them in, but the new ones fit in fine without any mods.
    Just be glad you arent getting type-x's!
    If you get splits they will come with an external crossover, and depending where you mount it running the wires for the tweeters can be a bit of a pain, but not too hard
    Aug 2008
    Quote Originally Posted by Philthy View Post
    K sounds good, last question then if i buy the Alpine Type S Coaxial Speakers that can i still connect the stock tweeter that is in my VS Ute? If so how do i do this?
    I think that question above is the last since the Alpine Type S Coaxial Speakers should hopefully fit in fine without any mods, the Alpine Type S Sub should be great matched with the Alpine Amp.
    Thanks again
    Matt
    Philthy's Avatar
    Aug 2005
    The speakers in the doors are seperate from the tweeters, so if you don't disconnect the stock tweeters from the dash then they will still work.
    I have never used alpine subs, so I can't say how good they are but I say you can't go past their speakers for the price. You should have a pretty good system after all this.
    VS Maloo
    Jan 2006
    Hawkesbury
    that whole blue piece u can see comes up. its a bit of stuffing around but not too bad. running wires down is usually ok. And as said before, if u buy splits they come with sperate tweeters, speakers & crossovers. If you want a basic wiring diagram i can whip one up, its not hard.
    Where do u plan on putting the sub?
    With the placing of the amps, this is where mine was behind the drivers seat. less heat than the floor and plenty of room. ps. the thing next to it is a splitter.
    --APOC--
    Aug 2008
    Well i reckon since the tweeters in the dash will still work after i wire up these Alpine S Type speakers that i will just leave them and use them like that because quite frankly i didn't even know they were there. My dad and i cant really be stuffed pulling off all the plastic dash to get to these two small speakers and then i betcha it wouldn't be easy to replace them because lemme guess u cant use the original wiring?
    As for my sub well that will be going in the back of the tray next to the fuel tank in a sealed box ported through to the cab so no need to worry about that with the amp sitting under the passenger seat in the cab.
    On the tweeter note i am hoping the original ones are ok for what they are i mean come on how much better can aftermarket tweeters really be considering there so small so i wont really miss having better aftermarket one would i? Also how do they run anyway off of the head unit? And any recommendations on a top quality head unit too maybe down the track or soon depending on $$$ since the one that came with it is a little worn?
    Could you maybe whip up a wiring diagram just so i can get some extra info and knowledge on this topic.
    Thanks
    Matt
  15. #15
    VS Maloo
    Jan 2006
    Hawkesbury
    Alright, here's one setup. This is how i ran my old system and it worked a treat.
    For the Sub, if your headunit has RCA outputs use them, if not then you can just use the rear left and rear right speaker outputs from the head deck and you'll have to tune the amp to suit.
    Using a 4ch 600W amp should do it. 150W rms per channel. ie. the MRP-F600.
    --APOC--
  16. #16
    VS S ute
    Nov 2008
    Try running a set of splits that have neodymium magnets as they are a lot smaller... boston pro60 and SPZ60 spring to mind but there might be others
    forget about the plastic speaker pods, you really need something solid. i made mine from tracing the outline of the pods onto 6mm MDF and then screwing together 3 rings of 18mm MDF to space it out...
    definitely kill the stock tweeters if you're putting new splits in, you dont have to take the dash apart just three screws holding the trim that goes along the front windscreen over the tweeters and it pops out. or leave em in and just disconnect the wiring if need be.
    i highly recommend running tweeters down low, even coaxially mounted if they allow for it rather than up on the dash
  1. VR-VS door pods and speaker mounts also front blinkers
    By r2e2 in forum Parts And Other Items For Sale
    Last Post: 28-08-2008, 12:27 PM
  2. FS: clear side indicators, vs clear taillights, vs 2 1/2" exhaust, speaker pods
    By lowrida56 in forum Parts And Other Items For Sale
    Last Post: 02-02-2008, 02:57 PM
  3. WTB - VR/VS Front Speaker Pods. Melb. Area
    By 1vngal in forum Swap / Wanted to Buy / Trade
    Last Post: 12-03-2007, 01:58 PM
  4. wtb - vr/vs speaker pods
    By stocky in forum Swap / Wanted to Buy / Trade
    Last Post: 28-09-2006, 07:20 PM
  5. VR-VS 6" speaker pods, info needed??
    By J_Rules in forum Car Audio
    Last Post: 15-06-2004, 07:12 PM
