i have a vr calais with standard eurovox radio stupid me entered wrong radio code to many times and now the radio is locked can any body help at all to know how to unlock the radio to re enter the code to which i got from holden thanks![]()
YES, you have put the stereo into shutdown mode, where there are 3 dashes on the display. Which means it wont let you re-enter the code until you leave the key in the ignition set to accessorys for an hour. Just have it parked in your driveway for an hour, then number 1 will appear on the display and you will be able to re-enter the code
Check the operators manual if you have it. Im sure you just have to walk away for 1/2 hour or an hour and it will let you try again. Good luck.
its all good thanks guys i disconnected the power for ten minutes then reconnected it and it reset it again its working fine know thanks again
How did you enter the wrong code too many times if you had it infront of you?
Originally Posted by davway
haha a valid question.. dyslexia![]()
