Results 1 to 3 of 3
Thread: Instaling a CD player in a VS comodore
    VS Executive
    Nov 2008
    South Australia
    Cool Instaling a CD player in a VS comodore
    i have installed my CD player in my car but it is to long to actually fit...
    it hits some black thing behind the dash that im not quite sure what its for. my CD player is similar to the sony XR-F5100. because it sits roughly a centimetre out the cd player bounces when i go over a bump which means i cant play cd's only the radio. so if u can tell me what to do please help.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Behind the unit is the heater box. Do you have RCAs (to an external amp) connected to the head-unit?
    If so then you'll probably need right angled RCA adaptors, which will give you sufficent room behind the unit.
    Something like these:
    Jaycar Electronics
    If you havent got RCAs connected then its just a matter of trying to keep the wiring loom under the unit while you insert it into the dash. It will be a tight fit either way.
    Basically what im assuming is the wiring is "coiling" up behind the unit and restricting it from going any further back, this is a common problem with VN-VS commodores and it takes a few times to get the unit in properly.
    Luke0011 is offline Car Audio Installer
    VZ Berlina 2005
    Jan 2007
    99% of aftermarket stereos fit in VS very nicely.Like what holdenboy says, if you have rca wires running amps you need right angle rcas so it sits in properly. The only units that dont fit are cheap and nasty ones that are deeper than 155mm.
  1. instaling boost gauge in supercharged vt
    By blwnvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-05-2009, 08:40 PM
  2. Instaling VP Calais retractable centre rear seat belt
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-08-2008, 01:13 PM
  3. For Sale SA V8 Comodore
    By 2 SL/ES in forum Vehicles For Sale
    Last Post: 02-03-2007, 12:27 AM
  4. Instaling Tacho Help!
    By r_i_d_a_h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2007, 10:32 AM
