Hey all, I have been having some troubles with my stereo in my vy ss.
Its just the stock unit. So i pulled it out and notice a couple of pins have come out of the plug.
I have no idea which holes to push these wires back into and hoping someone can tell me or push me in the right direction of the stereo plug pin and wire config.
thanks for any help.
Take a look at the top of the Headunit, there will be a wiring diagram.
If you search these forums you will find a wiring colour code. Just match them up and plug them back in.
From memory (depending on which way your looking at it)
The top section is for steering wheel controls
The middle are speakers
The bottom is your power/acc/ant
I dont need to know what wire colour does what i need to know where it goesin the stereo plug, the diagrm on stereo dont help either, it was steering wheel contrils that where playing up and speakers dropped in an out p/s.
But
I copied of a mates VY Stereo so its all good now, Cheers.
Correct me if i'm wrong.
If you know, for Eg. Mute was the yellow/black wire that was sitting loose.
And by looking at the diagram you can see that mute should be in 3 slot 1 row.
Would this not of fixed your issue?
