Results 1 to 5 of 5
Thread: Will i need a Capacitor or a bigger alternator
    VS5lTR's Avatar
    VS5lTR is offline MTX KID
    VS
    Nov 2008
    Default Will i need a Capacitor or a bigger alternator
    i am about to install 2 amps one mono and 1 4 channel and there going to
    be powering 2 subs and 4 speakers and a dvd head unit will it be fine on stock Vs v8 battery
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Should be OK, how much power does the monoblock and 4ch. amp put out (RMS)?
    You should be right if the mono is around 1000wrms and the spk. amp is around 300wrms (4x75).
    Either way I would personally upgrade the earth wiring at the battery, preferably using 2awg or bigger cable. Replace the stock earth terminal to body cable, add another one going to the strut tower bolt etc. Also add one going to the engine block.
    This will improve the charging system, most of the time it reduces the common problem of headlights dimming with bass notes.
    I will add though its probably obvious but dont play the system at more than half volume for longer than a few minutes with the car off.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    You won't need either unless you have electrical problems after you've installed them.
    VS5lTR's Avatar
    VS
    Nov 2008
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    You should be right with that amount of power, as StoneX has said....if you have problems after youve installed it thats when you should look at upgrading things.
  1. Capacitor
    By Deutscher in forum Car Audio
    Last Post: 14-08-2008, 06:43 PM
  2. Capacitor Problems.... help?
    By Deception in forum Car Audio
    Last Post: 06-08-2008, 07:47 PM
  3. Want Bigger Rims 20" or Bigger Legally
    By gooley in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2007, 03:15 PM
  4. Bigger alternator, can someone gfind me one!! VT
    By buzurk in forum Electrical Wiring / Questions
    Last Post: 12-06-2006, 09:20 PM
  5. Bigger alternator
    By sbkvp in forum Car Audio
    Last Post: 21-02-2006, 02:47 PM
