Results 1 to 13 of 13
Thread: distro block question
    VX Commodore Lumina
    Jan 2006
    South Adelaide
    Default distro block question
    Hey all,
    If I run a 4awg cable to a distro block, then to two 8awg cables to the amps, should I fuse the 8awg cables? The 4awg cable will be fused at the battery..
    I am just wondering whether I should buy a distro block that already has fuse holders in, or if I don't have to bother with fuses.. (The amps will be Alpine MRP-F300 and Pioneer GM-3200T).
    Also, is it ok if I ground both amps to another distro block, and then through a 4awg cable to the chassis, or would it just be better to use the 8awg straight from the amp and ground them to different points?
    Thanks in advance.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    As far as a fused DB goes, its up to you.... in my opinion a fused DB is not really needed, as long as the length of 8awg isnt more than a meter or so.
    Earthing is better if you use separate grounding points, using the 8awg i would run them to a good solid part of the car (not the parcel shelf etc) and sand back the area to bare metal, also use a split washer to stop it from coming undone over time.
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    Doesn't hurt to fuse it...but not necessary UNLESS your amps don't have their own fuses in the side of them.
    VX Commodore Lumina
    Jan 2006
    South Adelaide
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    One good thing about a fused distro block, especially a "circuit breaker" style one with switches, is that you can turn amps on/off independently without disconnected cables.
    Also some amps have their own fuses, making a fused block redundant.
    VS Acclaim
    Jun 2006
    the fuse is to protect the cable, not the amp - what amps arent fused these days? but i agree with Holdenboy i wouldnt bother if its a short run.
    multiple ground points are fine provided they are both solid (or you may introduce noise) but if you wish can ground via a distro to a central point there is no prob with this but remember to keep runs short.
    "The crisis of today is the joke of tomorrow" HG Wells
    VX Commodore Lumina
    Jan 2006
    South Adelaide
    Yeah I know the fuse is to protect the cable, which is why I was asking. I have seen distro blocks that go from one 4awg to four 8awg, so I wasn't sure whether only using two 8awgs would mean that they could get more current, and be overloaded. That doesn't make any sense, but I know what I mean lol.
    The amps are all fused, so I'll just get a normal distro block.
    Thanks for the help peoples .
    SweetWagon's Avatar
    SweetWagon is online now booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by Denno View Post
    The cable doesn't 'get' current, The amps 'pull' current through it. I really dont see the point of those 1x4gauge to 4x8gauge Distro blocks, seeing 4gauge can only handle approx 1.5 times more current draw than 8 gauge...
    If you're only running 2 amps, you can run the 4ga straight into the mono and 8ga from the mono to the other amp. OR terminate the 4ga with a ring terminal and also put ring terminals on the 8ga wire and bolt them together.
    VX Commodore Lumina
    Jan 2006
    South Adelaide
    Quote Originally Posted by vn6pwr View Post
    I know cable's don't 'get' current, it was just convenient to type that . Neither of the amps are a mono block... and the reason for needing a distro block to 8awg is because the 4awg ring terminal is too large to go under the screw in the amp for power (again, the amps are Alpine MRP-F300 and Pioneer GM-3200T). I just thought it'd be convenient to use the already purchased 4awg wiring kit to power two '8awg power wire requiring' amps. I didn't know that 4awg was 1.5 times 8awg though... I thought it was two 8awg equals one 4awg :S... But anyways, I don't think it'll be too much of a problem?
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    No mate you'll be right with 4awg......just buy a 1x4 - 2x8awg distribution block and you'll be right. As far as grounding goes, its up to you but i prefer seperate points. I would imagine theres little to no difference either way
    VX Commodore Lumina
    Jan 2006
    South Adelaide
    Aight sweet, a definitive answer, just what I was after!
    Cheers for the help everyone.
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Yeah 4 gauge is plenty fine to use. I would have thought 2x8gauge = 1x4 gauge but this is the site i use states otherwise Recommended Power and Ground Cable Sizes
    Luke0011 is offline Car Audio Installer
    VZ Berlina 2005
    Jan 2007
    sorry but 4 gauage on a 5 metre run can handle 150 amps b4 the wire will melt, and 8 gauge can supply 75 amps b4 the wire will melt or corrode or deteriorate. ANd exactly as JOE PEEPS said. The fuse is there to protect the wire only,no need to fuse it twice. BUt one thing that i have noticed over the years is there are actually thinner 4 gauge wire or 8 gauge wire than the next. As in one 4 gauge will have less strands than the other. Cheap bastards, but i wont mention the brands, LOL!!!
  1. L67 Block
    By Oken in forum V6 Development And Modification
    Last Post: 28-02-2008, 05:31 PM
  2. help on block??
    By 94ZZA in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-04-2007, 05:48 PM
  3. si block
    By farris in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-03-2007, 01:32 PM
  4. New (68y.o.) kid on the block.
    By alex120 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-03-2006, 08:24 AM
  5. LS1 Block
    By WILD VR CLUBBY in forum Parts And Other Items For Sale
    Last Post: 05-11-2005, 10:23 AM
