Results 1 to 3 of 3
Thread: Wiring Tweeters to amplifier
    VN Berlina Wagon 5ltr
    Sep 2008
    Question Wiring Tweeters to amplifier
    How you going out there guys?
    I have running in my car a little Sony Xplod 250 XM-502Z Amplifier which is a 2 Channel Mosfet amp, if it helps a link to the amp is
    Sony XM502Z 50W 2 Channel Car Amplifier Reviews Australia www.sony.com.au
    At the moment I have running 2 rear 6x9s (200W each) and a 600 Watt Clarion subwoofer, this is what came with the car when I purchased it.
    To cut a long story short, the tweeters (which I believe were wired up to the amp, as for some reason the Kenwood headunit I am using wont allow to connect front OR rear speakers - just wont work no noise) came disconnected, but I am uncertain as to where they were wired up in the first place if all channels are being used? The amp has a HIGH LEVEL with a left and right, posotive & negative simbols but with a different input I have no idea where they were or are ment to go, can anyone give me a hand with this? Cheers!
    Luke0011 is offline Car Audio Installer
    VZ Berlina 2005
    Jan 2007
    what tweeter are you talking about?? Most likely your sony amp is running the subwoofer, and the 6x9's are running off the headunit, but you say you cant run speakers off the headunit. YOu can blow the high level outs on the unit but the rca output will still work. DO you have sound coming from your 6x9's??
    Sep 2008
    I have a pair of seperate tweeters custom that came with the car, and yes the 6x9 are wired up to the amp, they work fine. The headunit wont run speakers off it because its dodgy!
  1. vs tweeters
    By Ratten in forum Car Audio
    Last Post: 22-08-2008, 08:40 PM
  2. vt tweeters
    By SthEastCustoms in forum Car Audio
    Last Post: 11-03-2008, 06:38 AM
  3. Wiring tweeters in a split sytstem question???
    By Semtex in forum Car Audio
    Last Post: 19-11-2007, 11:28 PM
  4. Tweeters
    By wooly72 in forum Car Audio
    Last Post: 17-01-2006, 12:15 AM
  5. Tweeters
    By Ant in forum Car Audio
    Last Post: 02-09-2005, 03:21 PM
