Results 1 to 6 of 6
Thread: VT Calais CD stacker problems
    VE SSV UTE
    Jun 2005
    Outer North Eastern Suburbs Melb
    Default VT Calais CD stacker problems
    My car has the standard 10 stacker that comes in the Calais. The CD player can not be successfully accessed. It has started displaying a "E-99" error, which, according to the manual, means that the microprocessor needs to be reset. I followed the instructions to do this, but it made no difference. I have ensured that the CDs are ok and in the correct way. I am sure someone out there has a brilliant solution, apart from replacing the unit, so I look forward to your responses. Thanks in anticipation.
    VT Acclaim
    Aug 2008
    SENATOR
    Oct 2008
    i'm having the same problem, resetting it has gotten me no where.
    resetting it just made the screen flash and then when you try to play is say that E-99 bull**** again
    SENATOR
    Oct 2008
    VE SSV UTE
    Jun 2005
    Quote Originally Posted by Branch View Post
    have you tried holding the eject button to reset it
    Pressing down the eject button just spits out the CD cartridge from the stacker. Thanks anyway.
    Luke0011 is offline Car Audio Installer
    VZ Berlina 2005
    Jan 2007
    Errorr 99 is a standard fault code. Needs to be sent off for repair. It can cost between 140 and 260 to fix.
  1. Eurovox 10 stacker problems!
    By Aus78Formula in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-11-2008, 04:35 PM
  2. Statesman Boot Cd Stacker Problems - Please Help
    By StevesVK in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-07-2006, 12:30 PM
  3. VT Calais Stacker
    By azman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-06-2006, 07:17 PM
  4. Cd stacker problems
    By glenhanley in forum Electrical Wiring / Questions
    Last Post: 26-05-2006, 06:36 PM
  5. Vx Gts Cd Stacker Problems
    By par in forum Car Audio
    Last Post: 01-05-2006, 10:52 AM
