Results 1 to 17 of 17
Thread: no sound from the sub
    VTSS GEN3, VKSSA REP V8, VP BT1 V8
    Feb 2006
    darlington
    Angry no sound from the sub
    hey.
    got my sub in on the weekend and wired it all up and still got no sound from it. we can feel slight movement from it but cant seem to get it to turn up to be able to hear anything. we playd with the controlls on the amp and head unit witch didnt make any differance... has this happend to anyone else before or does anyone have some ideas on what to try???
    BAD COP!! NO DONUT!!
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    Should put a multi meter on it see if ur gettin 12v to it..
    Check ur RCA's are connected correctly.
    Make sure ur turning the right dial on the amp, i did this mistake kept on turin Subsonic filter instead of the gain.
    Id check the voltage first, make sure its grounded on clean bare metal.
    Thats usually ppl first mistake not havin a good enough ground
    ________________________________________
    Feb 2006
    darlington
    VRII Acclaim
    Jul 2005
    The signal to the sub wont be 12V, and the signal will be fast so you probably wont get any meaningful reading. You could try measuring the resistance of the sub, you would have to remove it first though - may or may not help.
    I would try another sub, surely a mate would have one, or an auto store might bring one out to try if you tell them you would be interested in purchasing from them.
    VN Calais 5L
    Dec 2006
    whats your line out mode set to on the headunit? checked other settings on the headunit?
    Feb 2006
    darlington
    Quote Originally Posted by VNexecutive View Post
    as stated in the 1st post we'v done the head unit settings
    VE SV6 A5
    Dec 2008
    Check all your connections and if possible try your sub in another car or plug it straight into a hifi stereo that has a seperate subwoofer terminal to test what exactly the problem is. That way we can cut down on the possible problems.
    Feb 2006
    darlington
    yer its a bit of a pain in the a** trying to hook it up to someone elses sterio tho when its a 2000w 900rms sub lol most ppl dont have the amp to run somethin that big
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    You don't need a 900rms amp to test the sub though. Just find someone with a suitable amp and see if it works.
    Or hook someone elses sub up your system. That way you know if its the sub, or your setup and you can then start looking at it more in depth depending on what you find.
    Feb 2006
    darlington
    1991_Vn2nV's Avatar
    Mar 2006
    trentvy's Avatar
    trentvy is offline Dodges raindrops
    Vy S pack
    May 2008
    Kilsyth South
    ok stupid thought but ive done it. If the sub box has 2 differnt connections for the wire try putting them in the other connections. massive nooby mistake but Ive done it before :P
    Feb 2006
    darlington
    you meen swapping positive and negative wires or swap the wires goin to each voice coil?
    trentvy's Avatar
    Vy S pack
    May 2008
    Kilsyth South
    neither, On the sub box i worked on it had two jacks comming out of the box, as in two seperate, 1 pos 1 neg each. obviously one of them wasnt connected and one was. but thats another thing id make check your wires going to each voice coil.
  15. #15
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Where did you ground the amp to ?
    As Vn2nV has stated check or if possible earth it to a different location.
    Im assuming youve sanded back the area to bare metal?
    If youve got a multimter handy, check that there is 12+v going to the amps terminals.
    Get back to us when youve done these things.
  16. #16
    ImAHoon! is offline Banned
    Toyota Camry?
    Oct 2008
    Quote Originally Posted by da_almighty_fat_man View Post
    i have an amp that will fry it in about 10 seconds.
    wanna give it a try?
    what sub is it?
  17. #17
    1991_Vn2nV's Avatar
    Mar 2006
    I know his sub is a Pioneer, unsure what model though.
  1. Sound System high pitch sound
    By liquidforce_134 in forum Car Audio
    Last Post: 16-07-2008, 10:31 PM
  2. Better sound in a VY
    By pfx in forum Car Audio
    Last Post: 14-01-2007, 11:37 PM
  3. cai sound like pod ??
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-02-2006, 11:23 PM
  4. more sound
    By 96ss in forum Car Audio
    Last Post: 19-01-2006, 11:44 AM
  5. just bought sound system, will it sound good
    By pier_one in forum Car Audio
    Last Post: 02-10-2005, 01:27 PM
