Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: Sub Differnce
    VS Calais S1
    Jul 2006
    Kadina, SA
    Default Sub Differnce
    hey guys,
    I am looking at getting a pioneer sub for my car but i keep seeing two different models of the same sub. a 2 ohm one and a 4 ohm one.. well what part do the ohms play, is there going to be much difference between them and what would be better. cheers guys.
    FULLY TURBO vw caddy van :(
    Jul 2008
    Castle hill
    I'm assuming there is a Fairly big price difference between the 2 and 4 ohm sub?
    Look at your amp it should say:
    For eg. 400rms @ 2ohm
    200rms @ 4ohm
    Jul 2008
    Castle hill
    thought this would help you also -
    dual2 ohm voice coil in series = 4 ohms
    dual 2 ohm voice coil in parallel = 1 ohm
    dual 4 ohm voice coil in series = 8 ohms
    dual 4 ohm voice coil in parallel = 2 ohms
    you need compare it to the amplifier that you have. If your ampputs out the most power at 2 ohms, you'll want the 4 Ohm subwoofer . If you amp puts out the most power at 1 ohm or 4 ohms, you'll want the 2 Ohm subwoofer .
    VS Calais S1
    Jul 2006
    Kadina, SA
    ah ok well i just looked and the amp says 230w at 4 ohms and 340 at 2 ohms... so i want a 4 ohm sub, is that correct?
    Jul 2008
    Castle hill
    sorry i don't know what i was thinking - i was under the impression you mensioned dual voice coil.
    Best bet would be is post us your specs of the amp and the sub and match them up as best as possible.
    VS Calais S1
    Jul 2006
    Kadina, SA
    ok then well i will grab the specs and what have you and post them up when i get a chance... am stuck at work atm
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    The Pioneer subs that come in different impedence configurations ARE dual voice coil, so you were correct, Timmos.
    If the amp says 340 at 2 ohm, then go for the TSW307D4 and wire the coils in parallel (+ to + and - to -) then connect the amp to one set of the terminals.
    ImAHoon! is offline Banned
    Toyota Camry?
    Oct 2008
    Quote Originally Posted by StoneX View Post
    assuming the amplifier will actually happily operate at 2 ohms
    just because it says it can, doesn't always mean it will.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    If it's a name brand amp, they won't put a 2 ohm rating if it won't do it. They do actually test their products to find those power ratings.
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    All else being equal, and amp which is 2ohm capable will put out more power at 2ohm than 4ohm.
    You won't notice any difference in sound quality though if that's what you were getting at?
    VS Calais S1
    Jul 2006
    Kadina, SA
    hey guys... ok i got the specs for the subs and what not... also turns out that i got the specs wrong for my amp. But yeah stonex they were the ones i was looking at... so yeah anyway my amp at 4-ohms is 300x1 and at 2-ohms it is 450x1. As for subs I have been looking at a JBL GT512 which has 1100w max and 275w rms which has 4-ohm independence. I have also been looking at getting a Pioneer TS-W307D2 or D4 which has a 1200w max and both the 4-ohm and the 2-ohm ones are 400w rms. The pioneer subs are $40 more and i am leaning towards getting one of them. But what would be better? And so there is no difference in quality with the 2-ohm and 4-ohm ones, like one isnt clearer than the other and stuff?
    Jul 2008
    Castle hill
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    You have power to burn at 2 ohm... Make use of it with a 2 ohm sub, which is the TSW307D4. The D4 means dual 4 ohm voice coils.
    VZ Executive
    Nov 2008
  15. #15
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
  16. #16
    Toyota Camry?
    Oct 2008
    Quote Originally Posted by 2LOUD2OLD View Post
    go the pioneer, they are well proven subs
    wow! that was like the most useful post ever!
  17. #17
    VS Calais S1
    Jul 2006
    Kadina, SA
    lol yeah i think i will get the pioneer sub then lol i will be going to adelaide some time next week so i will try and pick one up then.
    But can someone explain this to me... confuses me a bit.. like how does dual 4 ohm voice coils equal 2 ohms?
  18. #18
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Basically, when you join two voice coils together in parallel (+ to + and - to -) it halfs the impedance. So if youve got two 4 ohm voice coils you get 2 ohms.
    If youve got two 2 ohm voice coils and join them in parallel, you get 1 ohm.
    What this does is allow you to extract the most power out of an amplifier. Impedance is basically resistance, the less the resistance on the amplifier, the more power it will produce (in general).
    Hope this helps, and didnt confuse you
  19. #19
    VS Calais S1
    Jul 2006
    Kadina, SA
  20. #20
    VE Calais-V 6.0L
    Aug 2005
    Hastings
  21. #21
    VS Calais S1
    Jul 2006
    Kadina, SA
  22. #22
    VZ Executive
    Nov 2008
    Quote Originally Posted by ImAHoon! View Post
    well that was an even more useful post, good work
  23. #23
    VS Calais S1
    Jul 2006
    Kadina, SA
    Just made a phone call and i should be picking up a Pioneer TSW307D4 late next week. Cheers for your help guys.
  24. #24
    bpottz's Avatar
    bpottz is offline Whipped By SAPOL
    VT Berlina
    Aug 2008
    South Oz
    EDIT: Nevermind found my answer elsewhere.
    single and dual voice coil subs?
    good link if you want to know about voil coils
    My VT Berlina [LIONLW] - Lowered, 18's, Leather
    http://forums.justcommodores.com.au/...tml#post863216
  25. #25
    Luke0011 is offline Car Audio Installer
    VZ Berlina 2005
    Jan 2007
    Electrical impedance, a measure of opposition to frequency varying electric current in an electric circuit.Electrical resistance is a ratio of the degree that an object opposes an electric current through it, measured in Ohms. Impedance is very different to resistance. But as a rule both do oppose current. A speakers dc resistance is very different to its impedance under load. If you measure the resistance from a multimeter of a speaker and then move the cone by pressing it in with your finger you will notice a significant change to resistance. As in dc resistance, because a speaker is supplied with an ac signal its resistance is called impedance because it opposes current depending on the frequency of the signal.
    Back to the topic, the main reason why a subwoofer has 2 voic coils is because the subwoofer can dissipate heat more efficiently than with just one coil. THus making it more efficient because with any conductor the resistivity rises with heat. With a rising resistivity the woofer needs more power to produce the same amount of loudness when hot. The design of the woofer and its ability to dissapate heat thus keeping the resitivity of the copper voic coil to a minimun recommended. A more efficient woofer is more reliable and has a lower chance of thermal deconstruction. There are basically two outcomes when deciding on a woofer, SPL ie; loudness of bass or SQ as in quality sounding bass. Generally most people will load up an amp to 2 ohm from there woofer/s. Which generally give you the bang for the buck your after. In my experience, and im sure others will disagree, running a sub a 4 ohms sounds better but you dont get louder bass. And dont get me wrong i have heard a lot of 2 ohm setups that sound fantastic.
  1. differnce between manual and auto motors, v6
    By mws in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-01-2008, 08:21 PM
  2. differnce between a vy and vy supercharged ???
    By vy low in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-02-2007, 04:58 PM
  3. main differnce between vs series 1 and series 2
    By frenzal_tom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-10-2005, 09:09 AM
