Results 1 to 7 of 7
Thread: Pioneer amp problem
    Feb 2007
    Default Pioneer amp problem
    Wondering if anyone on hear can offer some ideas on a problem with my Pioneer 5.1 receiver?
    Recently my Subwoofer has being making a thumping noise whenever I change the selection dial on the receiver. After taking the subby to authorised servicer, I was informed that there was nothing wrong with it and it was more than likely the receiver.
    After getting the subby home and re-checking all connections and the like I noticed that the thumping noise is the only sound the subby is making; there is absolutely no bass being produced when watching a movie or listening to music.
    Hoping someone can help. Thanks
    VU SS UTE / 5 Litre Volvo /Trusty Swift
    May 2008
    Penrith NSW
    Check your RCA leads they maybe wedged and squashed and the 2 wires might be touching..
    Why is it called Alcoholics Anonymous when the first thing you do is stand up and say, 'My name is Ray, and I am an alcoholic'?
    Feb 2007
    Quote Originally Posted by DVOLVO View Post
    Thanks for the reply. Thanks I'll give it a try.
    Subaru Liberty
    Feb 2007
    Does someone you know (friend/family) have a amp/receiver that you can use to test if your receiver is the problem? That way, it is pretty easy to find out if your receiver is dodgy, or something else is.
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    I would say wiring. I had this problem when a couple strands of speaker wire managed to reach the other terminals on the sub box. The subs wouldn't work intermittantly, and they thumped when turning the car/headunit off
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    It'll most likely be the RCA output circuit of the receiver. I've seen it a few times, I think it was just a transistor but you'll need Pioneer to fix it up.
    commsirac is offline Banned
    vx
    Aug 2007
    Does your sub have its own internal amp, or just uses outputs from the receiver? It will have/should have rca leads running to it if its got its own amp.
    I assume youve checked for the obvious, such as subwoofer on/off on the receiver.
    Sounds like a problem with the receiver.
    Perhaps check that your subby is working for yourself by putting another signal source into the sub, which of course will depend on whether its has internal amp or not.
  1. Pioneer CD tuner and electric aerial problem
    By VR mad in forum Car Audio
    Last Post: 20-05-2008, 11:02 PM
  2. Replies: 0
    Last Post: 14-10-2007, 10:14 AM
  3. Problem with Pioneer AVH-P5950DVD!!! Help!
    By 1991_Vn2nV in forum Car Audio
    Last Post: 07-09-2007, 05:36 PM
  4. MTX vs Pioneer
    By holden_69 in forum Car Audio
    Last Post: 06-05-2007, 10:20 PM
  5. f/s pioneer
    By bjd in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 02-05-2006, 02:30 PM
