After many searches over the net, looking for a sub enclosure to fit into the cavity beside the fuel tank of my ute, and with out much luck. I decided to design a enclosure, to suit my 12 inch sub.
This enclosure would be ideal for a shallow mounted sub. You should be able to use a 10 inch sub for this enclosure as well. Just make sure the sub you have or purchase is suited to a 31 Litre enclosure!
Feel free to use this for a sticky as it would be ideal!
What you will need
$60
18mm M.D.F
Two G clamps
Jigsaw
Drill
Piece of 4 by 2 (to use as a guide for the jigsaw to get a clean straight cut)
Wood screws
Liquid nails
All purpose silicon
Sample pot of paint
Can of clear spray paint
Get bunnings to cut the M.D.F to size for you. That way, all you will need to do is cut the front and side pieces at a 128 degree angle.
Plans
Completed with Silicon
After being painted and sub installed
Yes I know the sub is upside down, as the speaker wire terminals stopped the sub from fitting in properly. lol
Subwoofer Fitted (If useful)
Product Name: FEW-12 FUSION ENCOUNTER SUBWOOFER
VAS 100 L
QTS .343
QMS 4.155
QES .374
RMS Power 200 Watts
Peak Power 400 Watts
Sens (1W/1M) 91dB
Xmax (Pk to Pk) 22.5mm
Xmax (1 way) 11mm
Freq. Response 23Hz - 3KHz
Fs 27Hz
Voice Coil 2" Kapton SVC
Impedence 4 ohms
Mounting Diameter: 10.09" / 277mm
Mounting Depth: 5.02" / 127.5mm
Outside Diameter: 12.24" / 311mm
The Result
Sound Quality: The bass is much more deeper, due to better excursion.
The bass is now not muffled as the sub was originally placed behind the passenger seat, mounted in a custom enclosure, that I paid good money for!
My new ride with some upgrades.
www.teamfusion.info
Head unit: Fusion CA-CD500 Front Speakers: Fusion PP-CM650
Rear Speakers: FusionPP-FR6520 Subwoofer: Fusion PP-SW120 Amp For Front And Rear: Fusion PP-AM120040 Subwoofer Amp: Fusion PP-AM300010
i dont understand where it gose take a pic of it inyour ute![]()
My CaR dOsNt ChErP gEaRs, It JuSt KiCkS sIdEwAyS!
Here is the tray cover, and underneath that is the fuel tank. Just undo all the screws to get inside.
Here is a pic of the enclosure sitting beside the fuel tank.
www.teamfusion.info
ohhh yeh i see ill post up sum pics of wat i did.. i like your idea tho. my amps there tho lol.. might try 2 put another sub there lol
the middle bit is the sub but the other 2 side bits r shoe holders or wat ever..
ps. ya sub box looks like it got clouds on it lol
Yeah it has clouds on it, because i got board and wanted to airbrush lol. I like your idea, but I would be worried about getting defected. Is that a 12" you have?
www.teamfusion.info
yeh its a 12.. havnt been defected lol.. i got it searched for a gun lol.. thats about it haha
www.teamfusion.info
good work on the sub box.
ill be using this when i do my mates one. thanks alot
www.teamfusion.info
www.teamfusion.info
doest that trap door not leak is it ment to have a seal?
www.teamfusion.info
or buy this that suts behind one of the seats for about $150-
DNA Designer Audio : Sub Box Enclosures - Car Audio & Accessories
www.teamfusion.info
Is it possible to adapt this and make a sealed enclosure with a port going straight into the cabin through one of those holes? Would make for better sealing imo, I'm just not sure how to go about setting a box up for that.
Oh and 128 degree's? What the? From where?
To make a ported enclosure with the sub specs that I used, you would need to make the enclosure larger. Which would be hard, as there is limited space as it is.
If you are looking at the enclosure side on, from bottom to top, it is a 128 degree right angle.
www.teamfusion.info
hey mate i like your design... thinking of using it... but i have a pioneer 12" and the diameter is 327mm (16mm bigger than the fusion one), and the depth is 164mm (36.5mm deeper than fusion). As i cant really see how close the magnet is to the side of the box, do you think this sub will fit? if not, do you have any suggestions to make it fit? such as changing the angle, etc. thanks in advance for your help.
www.teamfusion.info
thanks man that would be a great help.
www.teamfusion.info
with this design, only problem i see is the firewall holes bein open, i had the covers off once after fidling, and its bad on a hot day as realy hot air comes in from under the car, and number 2, the fuel smell aint real good at times either, id go for similar design, but with a glass mould of maximum size, with an enclosed 10" like a bandpass box i think they call it, a box in a box, and vent the box infront of the sub sealed against those holes, anyone tried this idea?
Mines a sealed box with 12 inch pioneer slimline ported straight into the cab works awsome fiddling with ideas to put another 1400w pioneer slimline next to the other one in there.
