Results 1 to 10 of 10
Thread: Speaker Cutting Out
    Timoshii's Avatar
    Timoshii is offline Helpdesker
    VR Executive
    May 2008
    Bris-Vegas
    Default Speaker Cutting Out
    Hey guys,
    I am having a bit of a problem at the moment, would appreciate any advise possible, so I will try to explain as best I can.
    Setup:
    I have a Pioneer Dead Deck, with 2 stock front speakers ('94 VR Wagon) and 2 Pioneer (I think) rear speakers hooked up to the Head Unit. Also have an Amplifier and a Clarion 12' Subwoofer (just upgraded from a 10').
    Problem:
    Randomly, the sound to all 4 speakers will just cut out, they will stop producing sound, however the Head Unit is still on and playing, and the Subwoofer is still producing sound (basically the Sub still goes on). To the best of my knowledge its all connected ok as it was working fine for about a yearish and then one day it just started doing this.
    Actions taken so far:
    So far I have taken the head unit out and verified that all the cables are connected ok and that it is earthed (was a suggestion from a work colleague) however the issue is still present.
    FULLY TURBO vw caddy van :(
    Jul 2008
    Castle hill
    My best guess would be the internal amp in the Headunit is starting to die.
    How old is the pioneer headunit?
    Timoshii's Avatar
    VR Executive
    May 2008
    Bris-Vegas
    Quote Originally Posted by Timmos View Post
    Not that old, I could say MAX of 1 year 6 Months.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Might be the speaker wires, they could be touching together or touching metal sometimes. I know its a pain but just stake the unit out once more and re-insulate the speaker wire connections.
    It could be a few other things....does it happen at a particular time? like when opening/closing a door or going over a bump?
    Timoshii's Avatar
    VR Executive
    May 2008
    Bris-Vegas
    Quote Originally Posted by holdenboy View Post
    Might be the speaker wires, they could be touchong together or touching metal sometimes. I know its a pain but just stake the unit out once more and re-insulate the speaker wire connections.
    No it is completely random, which also makes it hard to troubleshoot.
    Also, I might have a look at that, need to go back in anyways as must have bumped the Air Conditioning Ducts or something because now no air comes out of the Vents (just the back of the console).
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Pioneer head units will mute the internal amp when a speaker wire is ground. You will have a wire intermittently touching the chassis. It's common that aftermarket speaker terminals touch the car as they have a bigger basket, so check that too.
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    If that dont work it sounds like you have your music too loud and the head unit is getting too hot. Usually when head units get too hot they cut the internal amp to prevent damage to the unit. Usually only to the amp though because it's the priamry heat generating part of a head unit. Then once it cools down it comes back on. Maybe try move the wires away from the rear of the unit?
    When i installed a Sony head unit the other day in a VR Berlina i dragged the wiring harness straight to the top of the head unit and supported by the clip below the air vents to allow heat to dissapate a bit easier.
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    my kenwood headunit does that when my speaker wires touch and the unit needs to be power off power on.
    vs berlina
    Dec 2008
    i had the same prob with a jvc head unit, took it out, rewired it insulating every wire again then put back in in a diff position (angled the rear of the unit up a bit) all back in now no probs
    Timoshii's Avatar
    VR Executive
    May 2008
    Bris-Vegas
    Thanks guys, I will try that all and let you all know.
    My father-in-law will be helping my by testing the Head Unit, we will take it out and set it up to the test bench and run it for a bit.
  1. amp cutting out
    By tyrefryer in forum Car Audio
    Last Post: 09-08-2008, 04:24 AM
  2. Amp keeps cutting out?? PLS HELP
    By Holdenboy_VS in forum Car Audio
    Last Post: 17-01-2007, 10:57 PM
  3. WTD - VS etc Speaker Door Pod Speaker Grills
    By lil_oneblue in forum Swap / Wanted to Buy / Trade
    Last Post: 08-01-2007, 08:38 PM
  4. cutting out
    By StatOmaN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-06-2006, 09:16 PM
