Results 1 to 5 of 5
Thread: Subwoofer wiring in VE sv6
    VE SV6 A5
    Dec 2008
    Default Subwoofer wiring in VE sv6
    Hi guys i just had my sound system completed in my ve it consists of the removal of the center speaker, all speakers replaced, a LC6 LOC and a zx350 kicker amp.
    My question is now i have just purchased a sub. To add that to the mix do i need to run another channel into the Lc6 and amp or is there a setting on my amp that will send the lows from the other two channels into this channel.
    Any opinions on how to wire this up will be much appreciated.
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    do you have spare channels on your amp if so ya can use that if they set it up for it
    if you didnt install it go to the place that did and get them to add the sub or if you play with it youll loose warranty
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    It would depend on how the system was set up when it was installed. Is that Kicker amp the ZX350.2 or ZX350.4?
    VE SV6 A5
    Dec 2008
    Quote Originally Posted by holdenboy View Post
    Hey mate its the 4 channel one. Do i split one of the other cables on the other channel to connect it to the third LC6 channel then the amp?
    VE Lumina
    Mar 2004
    Yeah mate, just splice into the front speaker wires behind the H/U and run them into the 5th and 6th channels on the LC6. So you will have the front speaker outputs from the H/U going to ch1,2 and 5,6 on the LC6 and the rear speaker outputs from the H/U going to ch3,4 on the LC6. Ch1,2,3,4 going to the Kicker amp running the 4 speakers and ch5,6 going to your sub amp.
    Otherwise your Kicker amp will probably have an RCA pass through (not 100% sure on this as i'm not familiar with Kicker gear.) You can just run a RCA cable from the RCA pass through on the Kicker amp straight into the inputs on your sub amp.
  1. subwoofer box
    By scolari in forum Car Audio
    Last Post: 09-12-2007, 03:43 PM
  2. subwoofer!
    By pr0n in forum Car Audio
    Last Post: 07-01-2007, 08:44 AM
  3. Wiring Subwoofer to Amp
    By tr3nt in forum Car Audio
    Last Post: 31-12-2006, 08:48 PM
  4. LPG with subwoofer
    By DanoSS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-07-2006, 07:51 PM
  5. Subwoofer
    By wooly72 in forum Car Audio
    Last Post: 19-11-2004, 02:52 PM
