Results 1 to 9 of 9
Thread: Best spot to ground amps on a VT commodore
    korn3172 is offline Chaps
    VT Commodore 2000 Olympic ED
    Aug 2008
    Default Best spot to ground amps on a VT commodore
    Hi,
    I was just wondering where the best spot to ground the amps in my VT commodore.
    I have them in the boot at the moment, but have recently put a VX SS body kit on, so it no longer has the bolts behind the tail lights.
    Is there a better spot to ground there? Or does someone know a better spot.
    VP Executive S2
    Aug 2005
    any exposed part of the body will do.
    scratch off paint if need be and bolt the ground there.
    (be careful of the fuel tank)
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    I would say without having a good look (havent worked on a VT for a while) is the rear seatbelt bolts. You'll have to remove the bottom part of the rear seat, sand back the area to bare metal and your away.
    sxc_sound's Avatar
    sxc_sound is offline getting Kustom
    VT Series 2 S pak
    May 2008
    Parkdale
    underneath of the parcel shelf, make the ground cable as short as possible and sand around where you bolt it on to make a nice clean connection.
    I stole these pics off this forum to demonstrate where im talking about.
    Aug 2008
    Quote Originally Posted by holdenboy View Post
    That sounds like a good one. Ill give it a go 2moro
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Yeah, depending on where the amps are mounted either one (the selt belt bolt or like what sxc_sound has suggested)
    The main thing is to sand back the area to bare metal, then screw/bolt your earth terminal to that area. You can even get some matching paint and go back over the spot if you like.
    VT Executive S2
    Oct 2007
    Croydon, VIC
    Just curious, is it possible to ground to the top of the boot? Not the boot lid, but the metal inside the boot beneath the parcel shelf?
    Got everything hooked up, thought I'd double check before I wire the power.
    FULLY TURBO vw caddy van :(
    Jul 2008
    Castle hill
    Quote Originally Posted by joshoVT View Post
    Theres no reason why you couldn't ground it there although i can't see it being a solid connection, i've got mine bolted under the back seats
    VT Executive S2
    Oct 2007
    Croydon, VIC
    I've got one amp grounded beneath the boot carpet which has worked fine, but I mounted my new amp on the roof inside the boot. It's not living there long, so we'll see... haven't had time to finish the wiring.
  1. Best Ground for VT/VX Boot
    By 1991_Vn2nV in forum Car Audio
    Last Post: 19-04-2008, 04:09 PM
  2. Diff on Ground
    By AdamAnt in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-03-2008, 12:39 PM
  3. Best Spot to Put Ground
    By tfacter in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-02-2008, 06:33 PM
  4. Ground Control
    By soyaman in forum Jokes/Humour
    Last Post: 25-02-2006, 10:52 PM
  5. Ground Wire in VR/VS?
    By SMIT in forum Car Audio
    Last Post: 17-01-2006, 11:21 PM
