where does the amp power lead go through on the firewall, coz im not real sure?? should i just drill a hole in the firewall?
Kenwood 12" sub 1200w( silver dish) with 800watt US Audio amp, what do yous reckon?
Is your car an auto or manual.
If its an auto you can use the clutch cable grommet on the drivers side. If its a manual there will be another grommet somewhere but im sure another person can help you with that.
The components youve got wont be too bad, im assuming the RMS rating of that amp is 800w, but it should go alright....provided its in the right box etc.
yeah its auto
Ahh, Ok then there will be a grommet just to the right of the brake booster on the firewall, near where the accelerator cable comes out. It will be an oval shaped grommet around 4cm high and 3cm wide.
