Hey guys, trying to help out a mate who has made a mess of his loom and cut the harness up. so now its up to me to try and rejoin it up to the kenwood loom.
although we cant find the 12v constant power, listed by many on the net as orange/white.
any ideas if this is a different colour or where this wire is???
it has to be somewhere
any help would be great
Check the fuse mate, i would say its blown.
yeah we checked them and went over it with a tester, somethings not right, but still seems weird that other vxs have a orange/white constant wire and there is non to be seen in this loom, hooked up through acc it all works though just need the constant
Thats a strange one.....no orange/white in the loom at all?
How bad did your mate cut the wiring harness up?
If all else fails and you simply cant find it....run a 12-16 gauge wire from the battery and to the head-unit (fused within 30cm of the terminal).
well he has just cut the end of the harness adaptor off, i dare say it will be there, it would have to be for the stock head unit that worked, worst comes to worst he will just have to run another power wire when he does one for the amp.
just strange that there is no orange one?
So your saying there's no orange/white wire in the harness adaptor wires that he cut or in the stock wiring loom?
have you maybe attatched it to another wire. jsut couldnt see the colors right and you attatched it to something else?
thats the only thing i think that may have been done, he already had some hooked up he said were right, they probs aren't,
it was only a 10 min look over today to try and figure out what mess he has gotten into, i reakon ill just have to pull it down and start again, but still there was no notable orange/white wire
take a good look at it man its gotta be there, otherwise your stock headunit wouldnt have been running
Mate, this thread is 3 year old, I dare say his stereo is working perfectly or he gave up by now. Check the date of the last post before posting
Just use a test light on the orange/black harness. If it is always on when the ignition is off and the drivers door is open, then it is constant +12V.
