Results 1 to 9 of 9
Thread: What AMP should i run
    VK Executive
    Apr 2008
    Default What AMP should i run
    hi,
    i just purchased a 12" Kenwood sub in the standard kenwood sealed box, the sub is 1200W peak, 400W rated, impedance 4 ohms. im just looking for the best amp to run it on, nothing to expensive tho.
    thanks
    SweetWagon's Avatar
    SweetWagon is online now booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by RayRay07 View Post
    hi,
    thanks
    I cant suggest anything but ideally you need something that makes ~400wrms @4Ohm. shouldnt be too hard to source something
    VP CALIBER Guest
    so your sub power can handel 400w all day so you need ..??? hang on are you gonna run speakers of a chennel what you gonna do first ???? if its just 1 sub 600w amp any brand get a 2 ch amp tell us more thanks you need to wake the sub up with more power so if you got 100w sub you need 150w to 200 w amp
    trentvy's Avatar
    trentvy is offline Dodges raindrops
    Vy S pack
    May 2008
    Kilsyth South
    pretty much match your subs output to the amps output. so vn6pwr is right. also being a sub it goes without saying get a monoblock
    VK Executive
    Apr 2008
    thanks for the input.
    yer, im just running the sub off the AMp, so it will be a monoblock im after.
    any particular brands? obviously not goin to get the no brand crap off ebay.
    VS 97 Series II
    Oct 2007
    Whalan, N.S.W
    Any particular budget you have?
    My new ride with some upgrades.
    www.teamfusion.info
    Head unit: Fusion CA-CD500 Front Speakers: Fusion PP-CM650
    Rear Speakers: FusionPP-FR6520 Subwoofer: Fusion PP-SW120 Amp For Front And Rear: Fusion PP-AM120040 Subwoofer Amp: Fusion PP-AM300010
    Fr3ak+--'s Avatar
    Fr3ak+-- is offline Closed On Monday
    Vt Exec 5 Speed
    Jul 2006
    Kingswood, Nsw
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    You don't have to use a monoblock... A 2 channel bridged will work just as well, will be cheaper and can be used for speakers or something in the future if you upgrade subs and need a bigger amp. Plus monoblocks are made to run 2 and 1 ohm subs, they'll make less power at 4 ohm.
    VS 97 Series II
    Oct 2007
    Whalan, N.S.W
    Quote Originally Posted by StoneX View Post
    He makes a practical point!
    www.teamfusion.info
