Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Thread: Sub goes with beat of motor????
    VR Commodore Exec
    Oct 2007
    Ballarat
    Default Sub goes with beat of motor????Please Help
    Hi all, I have intalled my sound system into my VR and i have just been listening to it when the car is turned off. Anyway i turned the car on and went to listen to some music then when my sub came on and before i put a song on the sub was making bass with the beat of my motor lol. Do i need to get some beefier RCA cables to stop interferance or do i have another problem?
    Cheers!
    SAV_117's Avatar
    SAV_117 is offline Donating Member
    VY Lumina
    Jul 2008
    bpottz's Avatar
    bpottz is offline Whipped By SAPOL
    VT Berlina
    Aug 2008
    South Oz
    yeah rca's are most likely picking up engine noise, if they are running down the same side as the power, run it on the other side
    My VT Berlina [LIONLW] - Lowered, 18's, Leather
    http://forums.justcommodores.com.au/...tml#post863216
    VR Commodore Exec
    Oct 2007
    Ballarat
    Well the RCA's are running down the middle and the power is running down the drivers side. But they meet at the back seat
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    VR Commodore Exec
    Oct 2007
    Ballarat
    Ok i will check over all those my earth etc. I might buy some more insulated RCA wire anyway.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    What brand head unit? Are the speakers running from the head unit or an amp? Do they do it too?
    VR Commodore Exec
    Oct 2007
    Ballarat
    Its a pioneer head unit basic model only about a year old. The speakers are connected to the head unit and no they don't do it they work fine its just the sub. When i rev the car the bass gets louder so it is in sinc with the motor.
    trentvy's Avatar
    trentvy is offline Dodges raindrops
    Vy S pack
    May 2008
    Kilsyth South
    VR Commodore Exec
    Oct 2007
    Ballarat
    trentvy's Avatar
    Vy S pack
    May 2008
    Kilsyth South
    VR Commodore Exec
    Oct 2007
    Ballarat
    Hahah i thought it was a joke but i wasn't sure so i pretended it wasn't so i didnt seem stupid lol.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    It's probably the head unit. They have an internal fuse on the RCA ground track which blows and causes your exact fault.
    VR Commodore Exec
    Oct 2007
    Ballarat
    Quote Originally Posted by StoneX View Post
    Is there any way that i can fix it?
  15. #15
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    If you want to be dodgy (or to even just test if that's the problem), you can get a bit of wire and link it from the head unit's chassis to the outer ring of the RCA socket on the back of the head unit... How you attach it to make good contact is up to you
    It'd be best to get it fixed by Pioneer though.
  16. #16
    SAV_117's Avatar
    VY Lumina
    Jul 2008
    generally rcas and power need to be 50mm apart if there not the power cord induces a voltage into the rca electromagnetic stuff blah blah anyway 50mm if there together thats your prob if not like daron said earths if thats not it get some filters
  17. #17
    VRII Acclaim
    Jul 2005
    Try disconnecting the RCA's at the amp and see if the problem is still there. If it is, the signal is coming through the RCA's and you know the problem is going to be with the head unit or RCA's. If the problem still exists you know it is going to be with the amp or amp wiring.
  18. #18
    VR Commodore Exec
    Oct 2007
    Ballarat
    Ok cool thanks for the help guys, i will try all those things tomorrow and see if i can figure out the exact problem. I'll let yous all know how i go.
    VR Commodore Exec
    Oct 2007
    Ballarat
    I just went out and tested then. I moved the positive and RCA's apart and the problem was still there, I unplugged the RCA's and the problem wasn't there. Does this mean its either the RCA's or my head unit or something else?
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Do this...
    Quote Originally Posted by stonex View Post
    if you want to be dodgy (or to even just test if that's the problem), you can get a bit of wire and link it from the head unit's chassis to the outer ring of the rca socket on the back of the head unit... How you attach it to make good contact is up to you
    it'd be best to get it fixed by pioneer though.
  21. #21
    VR Commodore Exec
    Oct 2007
    Ballarat
    OK i will try that tomorrow, which rca do i attach the wire from the head unit chassis onto? The white or red rca socket? Also can i attach the wire to the heatsink at the back of the head unit or does it have to be the chassis?
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Either RCA as the outer ring on all of them is just meant to be ground anyway. Yeah, the heatsink is fine as it's screwed to the chassis.
  23. #23
    VR Commodore Exec
    Oct 2007
    Ballarat
    Ok thanks mate! thanks for the help, i will try it today and let you know what happens.
  24. #24
    VR Commodore Exec
    Oct 2007
    Ballarat
    I connected a wire from the chassis of the head unit to the outer ring on the black RCA and it didn't fix the problem, it is still the same but it also has a whine to it. Does this mean that it is in my RCA wires? Do i need thicker ones?
  25. #25
    VR Commodore Exec
    Oct 2007
    Ballarat
    I just played some music with my car going but no sub connected and the rear speakers make a whine and crackle with the car. So i'm thinking that i really need to insulate the wires that run along the bottom of the car from the front.
  1. has me beat
    By arjvr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2008, 04:10 PM
  2. beat this
    By Garth in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-09-2006, 06:59 PM
  3. Can the VN beat the VE ?!?!
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-09-2006, 10:01 PM
  4. how to beat rust?
    By MontieVHSL/E in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-08-2006, 09:27 AM
  5. wat will beat eb tickford
    By vsclarion4u in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-03-2006, 07:02 PM
