Results 1 to 5 of 5
Thread: No amp output???
    1989 VN Berlina
    Jul 2008
    Gladstone, Queensland
    Default No amp output???
    Just wired up a 300W Clarion APA4300 but Im hearing nothing from it. At the moment its wired up to splits and nothing else. Only running the 2 channels. There is power to the amp but no output to the speakers. I checked the signal wire and speaker wires and they seem fine Am I missing something? Im new to all this so any help would really be appreciated!
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Have you wired the remote or control wire from the head unit to the amp?...wont work unless you have,,if it didnt have something to turn it off and on it would just flatten your battery so the wire tells the unit to turn on when your head unit is on.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    1989 VN Berlina
    Jul 2008
    Figured out the problem. Ended up being a pretty stupid mistake. I assumed that fading the sound to the front speakers would work with the amp... or is it meant to??? Anyway faded the speakers back to the middle and all of a sudden I have sound! lol
    Only problem I have now is that there is a whine and crackle in the speakers which goes with the motor whenever I have the car running. Ran RCA's, speaker wires and signal wire all on the opposite side to the power cable but still got the noise Any idea how to fix this?
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Could be a number of things;
    Where did you ground the amp to? and did you sand back the area to bare metal to get a good contact?
    What type of head-unit are you using?
    1989 VN Berlina
    Jul 2008
    Quote Originally Posted by holdenboy View Post
    Using a Pioneer HU at the moment. Found the major cause of most of the problem. Had a dodgy earth on my HU. Headunit was using the aerial as a earth. Found a good earth for the HU and disconnected the aerial (interfers ALOT and I never listen to much radio anyway). Almost all of the buzz of the engine has gone away and now there is only a very slight hum from the speakers which you can only hear with the volume right down. I can live with that, so its all good
  1. Alternator Output
    By mikek in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-10-2008, 08:35 AM
  2. vn alternator output
    By Keesh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-09-2008, 10:56 PM
  3. VT alarm output
    By craigvk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-05-2007, 08:25 PM
  4. amp power output?
    By SweetWagon in forum Car Audio
    Last Post: 23-03-2006, 09:41 PM
  5. Alternator Output
    By IVICA in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2004, 11:01 PM
