Results 1 to 6 of 6
Thread: Amp and Sub Setup With Gas tank in boot?
    Vt Berlina s2 00'
    Jan 2009
    Lilydale , Vic
    Default Amp and Sub Setup With Gas tank in boot?
    Can anyone shed sum light on how to setup up my sub and amp with a gas tank in the boot?
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    Drag the cables over the gas tank, if there's enough room alot of people have mounted the amp right next to their LPG tank on the roof, some have even mounted them on the boot lid roof itself. And yes, it's ok to mount the amp so close to an LPG tank. However if you still dont want to do that you can mount it on the sides of the boot (walls).
    With the sub maybe sit it on the wall or against the LPG tank?
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    You have a few options (like above).....or what i usually do unless a customer requests other wise is to mount the amp on the back of the subwoofer enclosure, and have the enclosure in the centre of the boot, facing rearwards, with the amp/back of enclosure sitting about and inch or 2 from the gas tank. The only downside is if you need to remove it, which means fully disconnecting the amp wiring.
    Vt Berlina s2 00'
    Jan 2009
    Lilydale , Vic
    Thanks for the ideas! Will try your suggestions One more thing how will i attempt to hold my sub down so it doesnt slide?
    VZ Executive
    Nov 2008
    Mike S is offline Car Audio Pro
    Jul 2005
    I'm assuming your car is a VT. You can use a couple of simple 'L' brakets screwed to the box and to the floor, or use a pair of tie down straps that are made for just this job and available from any car audio shop. Remember the VT floor has to lift up to get the spare wheel out so be careful not to screw anything into the tyre, and try and leave enuf cable length so you can lift the mat and the box up enuf to get the spare out.
    Mike
  1. Surge Tank/Swirl Pot Setup help
    By needwork2-4fillhabbit in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-05-2008, 04:30 PM
  2. Boot Setup
    By Infest in forum Car Audio
    Last Post: 30-10-2006, 08:59 AM
  3. what is the best boot setup for a vn
    By stocky in forum Car Audio
    Last Post: 01-05-2006, 04:32 PM
  4. sub setup in boot
    By patrix in forum Car Audio
    Last Post: 12-09-2005, 08:39 PM
  5. Fuel tank vapour line setup
    By Radical in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-09-2004, 01:32 PM
Tags for this Thread
