Results 1 to 4 of 4
Thread: WH Power Aerial
    00 WH Statesman
    Jan 2009
    Default WH Power Aerial
    Hey guys...
    I've got my head unit in.. connected everything up... but my power aerial doesn't go up... i have a Pioneer head unit... how do I make it work again?
    Thanks
    Dragoon
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    How did you connect your power aerial to the new head unit? It should be connected to the antenna turn on, if it doesn't give enough power you'll need to try the amp rem wire!
    00 WH Statesman
    Jan 2009
    I just bought a wiring converter... i assumed that it would be connected somewhere there... there is a small black plug though.. that could be the power aerial? ill try connecting it to the remote and let you know.. thanks
    Nov 2008
    Tullamarine, Vic
    That black plug is for the aerial signal most probably (Pioneers have the aerial signal on a wire out of the unit for some reason whereas most others are inbuilt as a socket in the unit).
    But you will need to connect the antenna rem wire to the wire in the factory harness to send the electric aerial up as well! Otherwise you'll just get no signal at all!
  1. Power aerial
    By Philthy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-11-2007, 01:51 PM
  2. $$$$ for a power aerial ?
    By Northern_Union in forum Car Audio
    Last Post: 15-09-2007, 12:24 PM
  3. Power Aerial
    By SSMarine in forum VY Holden Commodore (2002 - 2004)
    Last Post: 31-08-2006, 10:38 AM
  4. VX Power Aerial
    By WestieVYLS1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-12-2005, 12:43 AM
  5. Power Aerial Go Up, No Go Down
    By svs500 in forum Electrical Wiring / Questions
    Last Post: 30-04-2005, 02:25 PM
