Results 1 to 10 of 10
Thread: Sub THen Speakers
    COMMY VP 666's Avatar
    COMMY VP 666 is offline COMMY VP V6
    COMMODORE VP
    Dec 2008
    Thumbs down Sub THen Speakers
    Sub then speakers
    hey, yesterday must of been a bad day for me but
    i have 2 amps (wired perfectly)
    1 amp for sub and 1 amp for rear speakers
    first the sub has stopped working just faint stuffed up sound (which is fair enough)
    then later on when going back to my car i am getting a whining noise out of the rear speakers which are on the amp
    but it is only when the ignition/or engine started
    CAN ANYONE HELP
    THANKS
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    maybe check how many volts ya gettin to the amps and back of the deck - could be alternator or battery problem - i know when my battery is really low i get a bit of a whine whilst is charges up
    VT spac super6
    Nov 2008
    Riverton sa
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    see where i have moved this thread to, put any car audio related problems you have in the same area from now on.
    COMMODORE VP
    Dec 2008
    nope with the stero off it doesnt do it, just when the ignition is on or started lol
    im confused
    Mike S is offline Car Audio Pro
    Jul 2005
    Has this noise just suddenly started?. (I assume nothing else has changed). The only thing that can change is the power supply so I'm thinking you should get a load test done on your battery and make sure the alternator is charging. Have you actually had the engine running ?.
    After an onsite install the other day the customer calls and says the sub has stopped working, then the next day he calls and tells me the CD dosn't play past the first track. I make a special trip down there and find that the battery is dead, and the whole thing works fine after I jump start it. I'm not saying this is your problem, just that battery problems are very common and often mis diagnosed.
    Mike
    VT II Phantom
    Oct 2008
    Forest Lake, Brisbane
    COMMODORE VP
    Dec 2008
    earth should be fine, nah new battery and alternator should be good just happened randomly, the battery is fully charged
    hakhawk's Avatar
    Jan 2005
    COMMODORE VP
    Dec 2008
    i am running 2 amps
    so from the seat belt mount (middle one that pulls down)
    i have 1 cable, and due to my design of my amp box, i have 1 main ground cable conected into 2 cables going to the other amps.
    which all the connections should be really good, i volt checked them all and all seems good
    i dunno
  1. Speakers - sub woofer vs 9 x 6 speakers
    By adelaide paul in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-01-2009, 11:15 AM
  2. Replies: 2
    Last Post: 04-09-2008, 08:18 PM
  3. Replies: 18
    Last Post: 06-01-2008, 07:09 PM
  4. Where are all the speakers?
    By KITTAU in forum VE Holden Commodore (2006 - ?)
    Last Post: 10-01-2007, 02:53 PM
  5. Speakers for VS
    By vsberl in forum Car Audio
    Last Post: 05-01-2007, 12:05 AM
